$$external problem
Giorgio Garabello
$$external problem
Post by Giorgio Garabello »
It's the first time I try to create a function using the $$ external Qliberator directive.
I copied the following sample program from the manual:
50 REMark $$ external
60 DEFine Function FRA (x)
70 RETurn x-INT (x)
80 END DEFine
I compiled it and then loaded it into memory using the LRESPR command.
When I try to run it
PRINT FRA (3)
hangs on the RETURN statement with the following error: "non-numeric string", then it crashes?
I'm doing the tests on QPC2 ...
Some idea?
Re: $$external problem
Try line 50 without the space between $$ external
That is:
50 REMark $$external
EmmBee
Post by EmmBee »
Hi Georgio,
You need to do your tests on a real QL or Q-emuLator, and you will get the expected answers.
Unfortunately, these QLIB externals will not currently work with QPC2.
What happens is that x gets the value of an empty string,
and INT expects a numeric value, so this causes the error,
but the function would not return anyway.
EmmBee
Giorgio Garabello
Damn!
Are there any alternative ways to create extensions?
Damn!
Yes, in assembler ;) But why do you have to do this? It is no faster that incorporating the S*BASIC code in your (compiled) program. You could have a library of such toolkits and just paste them into your code as needed (as I do) or use Wolfgang's SBASIC linker..
EmmBee wrote:You need to do your tests on a real QL or Q-emuLator, and you will get the expected answers.
What is the technical reason for this?
Giorgio Garabello
Damn!
Assembler?....argh! (i'm ignorant)
I wanted to create a species of "API" to facilitate the work of other programmers ....
EmmBee
Post by EmmBee »
The trouble is apparently caused by QPC2 not recognizing it has been called from the Interpreter's #0.
The code will work if called from another compiled SBASIC Qliberator job, I've just tried this.
So, these QLIB externals do actually work with QPC2, but they currently cannot be used in Interpreted SBASIC.
EmmBee
Giorgio Garabello wrote: I wanted to create a species of "API" to facilitate the work of other programmers ....
Why not just leave the functions as SuperBASIC for people to incorporate within their own programs.
They could be coupled with the QL Library Manager by Ergon Development - http://www.dilwyn.me.uk/program/index.html
Giorgio Garabello
In my case it is an extension / command that acts in insertion on a Blackphonix system file ..
I want to make sure everyone can take advantage of the service but that no one can enter data that is formally wrong.
I believe that alternatively I used an executable program.
Of course it would be interesting to solve the problem of extensions!
Giorgio
