Qjewels
Qjewels
I have been trying to run Qjewels in Q68 DIP_MODE 6 - 512x384 Mode 33. This being the fastest Q68 Hi-Colour mode. But this screen mode does not have enough resolution.
It does run in DISP_MODE 7 - 1025x768 Mode 33.
I would like to use the 512x384 modd. Is the source available to implement this screen mode
Re: Qjewels
Derek,
yes, the sources are available to anyone who wants them. Simply send me a PM or e-Mail. To do what you have in mind, they are not needed, however (The full game is also a bit tricky to build with Turbo, all the bitmap resources and extensions and config blocks, and I never got around to write a proper build procedure):
Simply use menuconfig and configure the game to "Size of User Interface: Small" and it will come up with a 252x258 pixel window with small icons and run happily in the Q68 "small" screen mode.
I could claim QJewels was written with the Q68 in mind, but that would be lying ;)
Re: Qjewels
Hi Tobias,
I should known that there was config blocks.
I will configure tomorrow and try it on the Q68.
Re: Qjewels
Derek_Stewart wrote:I have been trying to run Qjewels in Q68 DIP_MODE 6 - 512x384 Mode 33. This being the fastest Q68 Hi-Colour mode.
Just for completeness, the fastest Hi-Colour mode is the Q60-like 512x256 (DISP_MODE 2). But 512x384 is my favorite.
Re: Qjewels
I have configured Qjewels with Menuconfig to use small icons.
Qjewels runs great in Q68 DISP_MODE 6: 512×384 MODE 33.
I find this resolution suitable for most my needs.
Re: Qjewels
QJewels source code is now available on my GitHub repository:
If someone wants to extend it to the full Candy Crush experience, feel free to branch it.....
Re: Qjewels
Nice-looking game tofro! :)
I had some trouble compiling it as I had to change a few fixed file locations. Also I dont (yet) know what sound_cde is; there are a few different sound-related toolkits out there. The one Ive always used on QPC2 (SMSQMulator has it built in) is called sound_bin and that doesnt have a device named SOUND5, AFAIA. I changed all that to my local circumstances and all seems to work well, sound an' all. Thank you!
Re: Qjewels
pjw wrote:Nice-looking game tofro! :)
That's interesting - I thought I used the sound driver that came with QPC2, but after all these years really can't be sure. Maybe it's the original one by Simon Goodwin? I don't know.
Good you managed to make it compile on your system!
Re: Qjewels
BTW there are some work-arounds around bugs in some older version of the QXL GD2 drivers in the code (they are marked) that should no longer be necessary with recent SMSQ versions and significantly slow down the animation - They should be removed (marked in comments).
Re: Qjewels
tofro wrote:BTW there are some work-arounds around bugs in some older version of the QXL GD2 drivers in the code (they are marked) that should no longer be necessary with recent SMSQ versions and significantly slow down the animation - They should be removed (marked in comments).
Yup, much better :)
