Note to self...
Whopper
Note to self...
Post by Whopper »
Do NOT create disk partitions of 2GB and then format them.
Take ages and ages and ages... well you get the picture.
Still waiting,
Whopper
You woke me for THAT!!!
Re: Note to self...
add an
unless you really think you need them.
8-)
(who has quite a number of 2Gig partitions)
Whopper
Re: Note to self...
Post by Whopper »
They take a lot of memory though.
I tried to attach a 2GB partition to WIN1_ and a 1776MB partition to WIN2_ and got an out of memory error.
I currently only have one 4GB DoM, waiting on a batch of CF IDE adaptors, so I was going to re initialise and repartition the DoM into 8 512MG partitions. That may give me a bit more flexibility and lower the RAM usage.
Whopper
Re: Note to self...
How much memory does a 2GB partition need?
Whopper
Re: Note to self...
Post by Whopper »
From the QubIDE manual -
Here is a little summary of different FAT size requirements regarding block sizes used :
 8 KBytes per 1 MBytes of storage with 1 Sec/Blk
 4 KBytes per 1 MBytes of storage with 2 Sec/Blk
 2 KBytes per 1 MBytes of storage with 4 Sec/Blk
 1 KBytes per 1 MBytes of storage with 8 Sec/Blk
 1 KBytes per 2 MBytes of storage with 16 Sec/Blk
 1 KBytes per 4 MBytes of storage with 32 Sec/Blk
 1 KBytes per 8 MBytes of storage with 64 Sec/Blk
A partition of 2 GBytes size with 64 Sectors/Block may be made with a 256 Kbytes FAT size only, but
the smallest file with 1 Byte per example will take a whole block of 64 sectors (32768 Bytes) of
storage
I used a 64 sector block size to get the smallest FAT.
So, I really am going to reinitialise my DoM. There would be far too much wasted space in a 32KB block size.
Whopper
Re: Note to self...
I didn't see you were doing this on a QL - That's really a waste of memory there.
128 to 256 MB sound a bit more reasonable.
Re: Note to self...
How much memory does your QL have?
Whopper
Re: Note to self...
Post by Whopper »
I have the standard 128KB plus the 512 from the QubIDE, so 640KB. believe me it doesn't last long. :(
Whopper
Re: Note to self...
Huh.... 640K isn't enough? Should be enough for anybody.
We'll have to do something bigger....
Whopper
Re: Note to self...
Post by Whopper »
Yeah, 640KB is too small.
I'll download some from the internet, :D
