Here is a new version of my IP Network driver and IP Router programs.
With this new version 1.12 of the IP Network Driver, you can now change the Network station number/IP Address, without having to reset the QL emulator. You can even flip the driver between IPNet and IPLocalNet modes.
I have also added a function to return the file server network mappings, and some function versions of some of the other commands.
Version 1.12 now also supports the NAServer with the IP Router program, with the new IP Router version 1.02
Documents are supplied in ODT, PDF and RTF formats.
IP Network Device Driver & IP Router
- Aurora
- IPRouter1_02Docs.zip
- (130.53 KiB) Downloaded 243 times
- IPRouter1_02.zip
- (12.12 KiB) Downloaded 232 times
- NETdriver112Docs.zip
- (172.62 KiB) Downloaded 242 times
- NETdriver112.zip
- (52.69 KiB) Downloaded 231 times
- QLvsJAGUAR
- Gold Card
Re: IP Network Device Driver & IP Router
I'm currently integrating those versions into QL/E. I see that IPBasic is still at version 1.00 (May 2016). Is that correct?
QL forever!
- Aurora
Yes. I haven't touched it in a while, and I haven't had any feedback about problems, or requests for improvements.QLvsJAGUAR wrote:I'm currently integrating those versions into QL/E. I see that IPBasic is still at version 1.00 (May 2016). Is that correct?
