Hi all,
Has anuone tried running Easymenu (from EasyPtr 4) on the Q68?
It seems very reluctant to run. When attempting to run it, it seems to hang for a while, and then shows up in the task list with no display. I have not been able to get it to run from this state.
The only way I've managed to get it to run is to run it is a separate SBASIC. Once it loads, you have to pick it, and then wait, and it will eventually show up and apparently run normally.
I get this result both on the included Q68 SD-Card, and my own, so it seems to be a general problem.
Rgds,
D.
Q68 and Easymenu
- Bent Pin Expansion Port
Re: Q68 and Easymenu
Hi Daniel,
Easyptr 4 will probably default to run in a Hi-Colour mode.
Have you tried the Q68 Hi-Colour modes. DISP_MODE 6 512 x 384 is the fastest Hi-Colour mode.
I do not have any Q68 to try this out... all sold.
If there is a problem with the Q68 SMSQ/E, send the details of the problem to me via PM and I will forward them to Wolfgang Lenerz. Or post the problem in the QL-Users list both Wolfgang and Marcel read the list.
I have sent Wolfgang an email to establish if there is a bug in the Q68 SMSQ/E.
Hi Derek,Derek_Stewart wrote:Hi Daniel,
If there is a problem with the Q68 SMSQ/E, send tge destails of the problem to me via PM and I will forward them to Wolfgang Lenerz. Or post the problem in the QL-Users list both Wolfgang and Marcel read the list.
I'll check it out tomorrow and let you know.
A couple more details:
- The other EasyPtr apps work fine.
- EasyMenu works fine on SMSQ/E 3.32 on QPC2, so the problem seems to be limited to the Q68.
Meanwhile, everything else that I've tried seems to work perfectly well.
Thanks,
D.
Any other native hardware to try? SGC?daniel_baum wrote:- EasyMenu works fine on SMSQ/E 3.32 on QPC2, so the problem seems to be limited to the Q68.
No, the Q68 is the first hardware "QL" that I've owned since I had a real QL a very long time ago. Since then I've only used software emulations.Peter wrote:Any other native hardware to try? SGC?daniel_baum wrote:- EasyMenu works fine on SMSQ/E 3.32 on QPC2, so the problem seems to be limited to the Q68.
D.
HI Daniel,
Here is the reply from Wolfgang:
Wolfgang wrote: Hi Derek,
Easymenu runs on the Q68. It just takes a VERY long time to load (1-3 mins depending on the screen mode). Just be patient. Once loaded, it runs ok.
I think that Easymenu is a compiled program, do you know whether the source code is available for it?
Tested in modes 1,4,7.
Regards
Wolfgang
NB: please let people know that they can ask those questions directly of me through the mailing list.
derek@q40.de wrote: On 27/12/2017 22:25, Derek wrote:
> Hi Wolfgang,
> There has been a question posted on the QL Forum:
> http://www.theqlforum.com/viewtopic.php? ... 821#p20816
> Of an issue with Easymenu not starting up correctly on the Q68.
> I do not have a Q68 to try Easyptr4, to all Q68s being sold.
> Can you try Easyptr4 on your Q68.
> Can Easyptr4 run in a non-Hi-Colour mode?
> RegardsDerek
