I have come across a couple of manuals for the rare Ace Card and Trey Card by MIracle Systems.
Does anyone want this to scan in - it is only two sides of A4, but folded to form 8 pages of A6 which might make it awkward to scan in legibly - it might need to be blown up to A3 size before scanning?
Miracle Systems ACE CARD & TREY CARD MANUAL
Re: Miracle Systems ACE CARD & TREY CARD MANUAL
Hi Rich,
If want to send them to me, I have some software that will handle the scanning.
- XorA
- Site Admin
Do you mean when unfolded its one A3 sheet?RWAP wrote:I have come across a couple of manuals for the rare Ace Card and Trey Card by MIracle Systems.
If so I have an A3 scanner!
It is only currently an A4 sheet - but I think the text might be too small for accurate scanning.
I will send it to Derek first and we can take it from there...
Shame I don't recall ever having seen this hardware....
- XorA
- Site Admin
No way, the scanners of today are much higher resolution than the printers of the 80sRWAP wrote:It is only currently an A4 sheet - but I think the text might be too small for accurate scanning.
I suppose the manual (if original) is not printed with a home printer but with typographic techniques.
Resizing it (with a copier?) before scanning would be ineffective; on the contrary it's important to use a good scanner correctly.
I offer to make post-scanning enhancements; please feel free to send me the scanned files if you consider this helpful
I have scanned OCRed the scan and made a searchable A4 PDF.
I have emailed the PDF to Dilwyn for his web site.
