System test software
Is the system test program mentioned in the service manual available somewhere?
- klausfrank
- Chuggy Microdrive
Re: System test software
I have a master - still working from a backup ! I have both microdrive and disc.
Regards
Regards
Great! I sent you a PMklausfrank wrote:I have a master - still working from a backup ! I have both microdrive and disc.
Regards
I don't remember If we have preserved or notklausfrank wrote:I have a master - still working from a backup ! I have both microdrive and disc.
Regards
Would anyone be. able to share this one with me, trying to debug my microdrive issues, it might prove useful. Thanks!
Hi, Sorry for stealing the thread, anyone willing to share the test program?
thanks in advance
/Chris
thanks in advance
/Chris
- klausfrank
- Chuggy Microdrive
The program (below) that goes through and tests stuff (originally on the ROM of the factory test jig, here: https://qxl.win/test_jig_with_dongle.htm) is just in SuperBasic and tests mdv functions read/write etc etc, but it's not really much good for fault finding as it will just either pass or fail
1000 MODE 256
1010 set_scr
1015 REMark SYSCOMP V1.1
1020 REMark COMBINED SYS2/COMPATIBILITY
1030 REMark EDITED 19.9.85, C.Selby
1060 sv_respr=RESPR(10000)
1070 PAUSE 10
1080 test1
1085 STOP
1090 DEFine PROCedure test1
1100 display
1110 sound
1120 network
1130 rs_232_c
1140 keyboard
1150 joysticks
1160 clock
1170 mdrive
1190 complete
1200 END DEFine test1
1210 DEFine PROCedure set_scr
1220 WINDOW 512,256,0,0
1230 PAPER 0
1240 INK 7
1250 CLS
1260 WINDOW 400,200,50,20
1270 BORDER 4,255
1280 END DEFine
1290 DEFine PROCedure display
1300 INK 7
1310 CLS
1320 PRINT "Display test:";
1330 FLASH 1:PAPER 7:INK 0:PRINT " FLASHING TEXT ":PAPER 0: INK 7:PRINT " FLASHING TEXT":FLASH 0
1340 PRINT \"Colour test:"\
1350 FOR row=0 TO 7
1360 FOR col=0 TO 7
1370 INK row:STRIP col
1380 PRINT "Test";
1390 END FOR col
1400 PRINT \
1410 END FOR row
1420 STRIP 5:INK 2
1430 PRINT "Display test complete"\"Type OK to continue"
1440 STRIP 0:INK 4
1450 REPeat l:a$=INKEY$:IF a$="o" OR a$="O" THEN EXIT l
1460 PRINT "O";
1470 REPeat l1:a$=INKEY$:IF a$="k" OR a$="K" THEN EXIT l1
1480 PRINT "K"
1490 PAUSE 50
1500 END DEFine display
1510 DEFine PROCedure sound
1520 INK 7
1530 CLS:PRINT "Sound test"\\"Two cycles of Trimphone"
1540 PRINT "followed by low pitch tone"
1550 FOR l=1 TO 2
1560 FOR m=1 TO 2
1570 FOR n=1 TO 6+2*m
1580 BEEP 100,1
1590 a$=INKEY$(1)
1600 END FOR n
1610 a$=INKEY$(20)
1620 END FOR m
1630 a$=INKEY$(50)
1640 END FOR l
1650 BEEP 0,240:PRINT \\
1660 PRINT "Sound test complete"\\
1670 STRIP 5:INK 2
1680 PRINT "If sound OK, type OK to continue"
1690 REPeat l2:a$=INKEY$:IF a$="o" OR a$="O" THEN EXIT l2
1700 STRIP 0:INK 4:PRINT "O";
1710 REPeat l3:a$=INKEY$:IF a$="k" OR a$="K"THEN EXIT l3
1720 PRINT "K"
1730 BEEP
1740 END DEFine sound
1750 DEFine PROCedure network
1760 INK 7
1770 CLS:PRINT "Network test: ";
1780 tmode=PEEK(164000):POKE 164000,24
1790 POKE 98306,24
1800 IF PEEK(98336)MOD 2 THEN INK 2:PRINT "Failed":STOP
1810 POKE 98306,152
1820 IF PEEK(98336)MOD 2<>1 THEN INK 2:PRINT "Failed":STOP
1830 INK 4:PRINT "OK"
1840 POKE 98339,tmode:POKE 164000,tmode
1850 PAUSE 50
1860 END DEFine network
1870 DEFine PROCedure rs_232_c
1880 CLS:INK 7
1890 PRINT "RS-232-C loopback test"
1900 STRIP 0:INK 7
1910 OPEN#3;ser1:OPEN#4;ser2
1920 FOR n=9600,4800,2400,1200,600,300,75
1930 BAUD n
1940 PRINT n;" baud: ";
1950 IF n=9600 THEN
1960 t$="1234567890abcdefghijklmnopqrstuvwxyz"
1970 t$=t$ & t$ & t$
1980 FOR i=1 TO 19
1990 rssub
2000 NEXT i
2010 ELSE
2020 t$="Test"
2030 rssub
2040 END IF
2050 INK 4
2060 PRINT "OK"
2070 INK 7
2080 END FOR n
2090 CLOSE#3:CLOSE#4
2100 PRINT \"RS-232-C test complete"
2110 END DEFine rs_232_c
2120 DEFine PROCedure rssub
2130 PRINT#3;t$:PRINT#4;t$
2140 INPUT#3;a$
2150 INK 2
2160 IF a$<>t$ THEN PRINT "failed":STOP
2170 INPUT#4;b$
2180 IF b$<>t$ THEN PRINT "failed":STOP
2190 END DEFine srsub
2200 DEFine PROCedure keyboard
2210 BORDER 4,255
2220 CLS:CURSOR 0,80
2230 STRIP 0:PRINT "Keyboard test"\\
2240 STRIP 5:INK 0:PRINT "Press the dark blue key":STRIP 0:INK 7
2250 CURSOR 0,0
2260 row1$="F1Es1 2 3 4 5 6 7 8 9 0 - = ` \ "
2270 row2$="F2TaQ W E R T Y U I O P [ ] "
2280 row3$="F3CLA S D F G H J K L ; ' En"
2290 row4$="F4ShZ X C V B N M , . / Sh"
2300 row5$="F5CtLeRiSpUpDoAl"
2310 STRIP 0:INK 7
2320 PRINT row1$\row2$\row3$\row4$\row5$
2330 x=0
2340 FOR n=232,27,49,50,51,52,53,54,55,56,57,48,45,61,96,92
2350 CURSOR x*12,0
2360 STRIP 1:PRINT row1$(x+1 TO x+2);
2370 REPeat loop:IF CODE(INKEY$(-1))=n THEN EXIT loop
2380 CURSOR x*12,0
2390 STRIP 4:PRINT row1$(x+1 TO x+2);
2400 x=x+2
2410 END FOR n
2420 x=0
2430 FOR n=236,9,113,119,101,114,116,121,117,105,111,112,91,93
2440 CURSOR x*12,10
2450 STRIP 1:PRINT row2$(x+1 TO x+2);
2460 REPeat loop2:IF CODE(INKEY$(-1))=n THEN EXIT loop2
2470 CURSOR x*12,10
2480 STRIP 4:PRINT row2$(x+1 TO x+2);
2490 x=x+2
2500 END FOR n
2510 CURSOR 0,20:STRIP 1:PRINT "F3";
2520 REPeat loop3:IF CODE(INKEY$(-1))=240 THEN EXIT loop3
2530 CURSOR 0,20:STRIP 4:PRINT "F3";
2540 STRIP 1:PRINT "CL";
2550 caps=40*16^3+136
2560 REPeat loop4:IF PEEK_W(caps)<>0 THEN POKE_W caps,0:EXIT loop4
2570 CURSOR 24,20:STRIP 4:PRINT "CL";
2580 x=4
2590 FOR n=97,115,100,102,103,104,106,107,108,59,39,10
2600 CURSOR x*12,20
2610 STRIP 1:PRINT row3$(x+1 TO x+2);
2620 REPeat loop5:IF CODE(INKEY$(-1))=n THEN EXIT loop5
2630 CURSOR x*12,20
2640 STRIP 4:PRINT row3$(x+1 TO x+2);
2650 x=x+2
2660 END FOR n
2670 CURSOR 0,30:STRIP 1:PRINT "F4";
2680 REPeat loop6:IF CODE(INKEY$(-1))=244 THEN EXIT loop6
2690 CURSOR 0,30:STRIP 4:PRINT "F4";
2700 STRIP 1:PRINT "Sh";
2710 REPeat loop7:IF KEYROW(7)=1 THEN EXIT loop7
2720 CURSOR 24,30:STRIP 4:PRINT "Sh";
2730 x=4
2740 FOR n=122,120,99,118,98,110,109,44,46,47
2750 CURSOR x*12,30
2760 STRIP 1:PRINT row4$(x+1 TO x+2);
2770 REPeat loop8:IF CODE(INKEY$(-1))=n THEN EXIT loop8
2780 CURSOR x*12,30
2790 STRIP 4:PRINT row4$(x+1 TO x+2);
2800 x=x+2
2810 END FOR n
2820 STRIP 1:PRINT "Sh";
2830 REPeat loop9:IF KEYROW(7)=1 THEN EXIT loop9
2840 STRIP 4:CURSOR 288,30:PRINT "Sh";
2850 STRIP 1:CURSOR 0,40:PRINT "F5";
2860 REPeat loop9:IF CODE(INKEY$(-1))=248 THEN EXIT loop9
2870 STRIP 4:CURSOR 0,40:PRINT "F5";
2880 STRIP 1:PRINT "Ct";
2890 REPeat loop10:IF KEYROW(7)=2 THEN EXIT loop10
2900 CURSOR 24,40:STRIP 4:PRINT "Ct";
2910 x=4
2920 FOR n=192,200,32,208,216
2930 CURSOR x*12,40
2940 STRIP 1:PRINT row5$(x+1 TO x+2);
2950 REPeat loop11:IF CODE(INKEY$(-1))=n THEN EXIT loop11
2960 CURSOR x*12,40
2970 STRIP 4:PRINT row5$(x+1 TO x+2);
2980 x=x+2
2990 END FOR n
3000 STRIP 1:PRINT "Al";
3010 REPeat loop12:IF KEYROW(7)=4 THEN EXIT loop12
3020 STRIP 4:CURSOR 24*7,40:PRINT "Al"
3030 STRIP 0
3040 CURSOR 0,120:INK 4:PRINT "Keyboard test complete"
3050 PAUSE 50
3060 END DEFine keyboard
3070 DEFine PROCedure joysticks
3080 joy$="F1F2F3F4F5LeRiSpUpDo"
3090 CLS:PAPER 0:INK 7
3100 PRINT "Joystick test"
3110 STRIP 5:INK 0:PRINT "Plug in joystick test board"\"and type keys from left to right"
3120 CURSOR 0,60:STRIP 0:INK 7:PRINT joy$
3130 x=0
3140 FOR n=232,236,240,244,248,192,200,32,208,216
3150 CURSOR x*12,60:STRIP 1:PRINT joy$(x+1 TO x+2)
3160 REPeat loop12:IF CODE(INKEY$(-1))=n THEN EXIT loop12
3170 STRIP 4:CURSOR x*12,60:PRINT joy$(x+1 TO x+2)
3180 x=x+2
3190 END FOR n
3200 CURSOR 0,110:STRIP 0:INK 4:PRINT "Joystick test complete"
3210 PAUSE 50
3220 END DEFine joysticks
3230 DEFine PROCedure complete
3240 PAPER 0:INK 4:CLS
3250 CSIZE 1,1:CURSOR 50,60
3260 PRINT "QL test complete"
3270 END DEFine complete
3280 DEFine PROCedure clock
3290 CLS:PAPER 0:INK 7
3300 PRINT "Real-time clock test"\\
3310 PRINT "Reset test: ";
3320 rtc=24*16^3
3330 POKE rtc,0
3340 IF PEEK_L(rtc) THEN fail_rtc:RETurn
3350 INK 4:PRINT "OK":INK 7
3360 PRINT "Step test: ";
3370 INK 2
3380 FOR n=1 TO 4
3390 FOR byte=0 TO 3
3400 POKE rtc+1,255-2^(byte+1)
3410 IF PEEK(rtc+3-byte)<>n THEN fail_rtc:RETurn
3420 END FOR byte
3430 END FOR n
3440 INK 4:PRINT "OK":INK 7
3450 PRINT "Count test: ";
3460 POKE rtc,0
3470 PAUSE 180
3480 IF PEEK_L(rtc)<>3 THEN fail_rtc
3490 INK 4:PRINT "OK"
3500 INK 7
3510 END DEFine clock
3520 DEFine PROCedure fail_rtc
3530 failed=1
3540 INK 2:PRINT "Failed"
3550 INK 7
3560 STOP
3570 RETurn
3580 END DEFine
5000 DEFine PROCedure mdrive
5010 mdvtest
5012 compat
5013 END DEFine mdrive
5014 DEFine PROCedure compat
5020 set_scr
5050 REMark microdrive compatibility
5060 set_scr
5070 CSIZE 2,0
5080 rtc=24*16^3
5090 DIM dt(3,2)
5100 DIM t(2)
5110 DIM s(2)
5120 write
5130 setup
5140 readback
5150 dt(1,1)=t(1):dt(1,2)=t(2)
5160 swap
5170 setup
5180 readback
5190 dt(2,1)=t(1):dt(2,2)=t(2)
5200 swap
5210 setup
5220 readback
5230 dt(3,1)=t(1):dt(3,2)=t(2)
5240 test
5250 END DEFine compat
5260 DEFine PROCedure write
5265 CSIZE 2,1:PRINT "DRIVE COMPATIBILITY TEST":CSIZE 0,0
5270 AT 3,0 :PRINT"Writing onto microdrives..."
5280 FOR d=1 TO 2:SBYTES "mdv"&d&"_dump",0,32*1024
5290 END DEFine
5300 DEFine PROCedure readback
5310 CLS
5320 FOR i=1 TO 2
5330 s(i)=PEEK_L(rtc)+1
5340 IF PEEK_L(rtc)<>s(i) THEN GO TO 5340
5350 LBYTES "mdv"&i&"_dump",131072
5360 set_scr
5370 t(i)=PEEK_L(rtc)-s(i)
5380 CLS
5390 NEXT i
5400 PRINT "Times were ";t(1);" & ";t(2)
5410 END DEFine
5420 DEFine PROCedure swap
5430 AT 3,6:PRINT "Swap cartridges"
5440 AT 4,6:PRINT "then press space bar"
5450 PAUSE
5460 END DEFine
5470 DEFine PROCedure setup
5480 PRINT \"Setting up..."
5490 DIR mdv1_:DIR mdv2_
5500 PAUSE 100
5510 END DEFine
5520 DEFine PROCedure output
5530 CLS
5540 PRINT:PRINT
5550 PRINT " Times were"
5560 PRINT
5570 FOR i=1 TO 3
5580 PRINT " Run ";i;": ";dt(i,1),dt(i,2)
5590 NEXT i
5600 END DEFine
5610 DEFine PROCedure test
5620 REMark
5630 IF dt(1,1)<=8 AND dt(1,2)<=8 AND dt(2,1)<=8 AND dt(2,2)<=8 AND dt(3,1)<=8 AND dt(3,2)<=8 THEN
5640 pass
5650 ELSE
5660 fail
5670 END IF
5680 END DEFine
5690 DEFine PROCedure pass
5700 output
5710 PRINT:PRINT
5720 PRINT" DRIVES PASSED":CSIZE 2,0
5725 PAUSE 100
5730 END DEFine
5740 DEFine PROCedure fail
5750 output
5760 PRINT:PRINT
5770 FLASH 1:PRINT" REJECT UNIT"\" RECORD DETAILS"\" HAND TO FAULT FINDING":FLASH 0:CSIZE 2,0
5780 END DEFine
5790 DEFine PROCedure update
5800 DELETE mdv1_mcomp:SAVE mdv1_mcomp
5810 END DEFine
5820 DEFine PROCedure mdvtest
5830 MODE 256
5840 set_scr
5845 PRINT "PLACE BLANK TAPES IN DRIVES"\"AND PRESS SPACE..."
5847 BEEP 150,2:PAUSE 5:BEEP 150,2:PAUSE
5850 REMark MICRODRIVE TEST
5890 sv_respr=RESPR(10000)
5900 PAUSE 10
5910 scrset 1
5920 spin 1
5930 mdtest 1
5940 PAUSE 40
5950 scrset 2
5960 spin 2
5970 mdtest 2
5980 END DEFine mdvtest
5990 DEFine PROCedure scrset (drive)
6000 WINDOW 512,256,0,0
6010 PAPER 0
6020 INK 7
6030 CLS
6040 WINDOW 400,200,50,20
6050 BORDER 4,255
6060 CSIZE 2,1: PRINT "MICRODRIVE ";drive;" FORMAT TEST"
6070 CSIZE 0,0
6080 END DEFine
6090 DEFine PROCedure mdvr(drive)
6100 REMark (run,write & erase)
6110 POKE 164000,24
6120 POKE 98336,3:POKE 98336,1
6130 IF drive = 2 THEN POKE 98336,2 : POKE 98336,0
6140 POKE 98336,12
6150 END DEFine
6160 DEFine FuNction ftest(drive)
6170 LOCal total,bad,errcode
6180 INK 0:STRIP 5
6190 formt(drive)
6200 INK 7:STRIP 0
6210 IF errcode THEN INK 7:PRINT\"Format failed"
6220 IF total<214 THEN errcode=1:INK 7:PRINT\ "Total sectors too low"
6230 IF total>225 THEN errcode=1:INK 7:PRINT\"Total sectors too high"
6240 IF bad>7 THEN errcode=2:INK 7:PRINT "Too many bad sectors:"
6250 PRINT "Bad/total sectors:"!bad;"/";total
6260 RETurn errcode
6270 END DEFine
6280 DEFine PROCedure formt(drive)
6290 LOCal drive$,n
6300 drive$="mdv"&drive&"_test"
6310 POKE_W sv_respr+8,LEN(drive$)
6320 FOR n=1 TO LEN(drive$):POKE sv_respr+9+n,CODE(drive$(n))
6330 CALL 63488,sv_respr:REMark hex F800
6340 errcode=PEEK_L(sv_respr)
6350 total=PEEK_W(sv_respr+6)
6360 bad=total-PEEK_W(sv_respr+4)
6370 END DEFine
6380 DEFine FuNction ftest1(drive)
6390 IF ftest(drive) THEN RETurn 1
6400 END IF
6410 RETurn 0
6420 END DEFine
6430 DEFine PROCedure mdtest(drive)
6450 IF ftest1(drive) THEN
6460 STRIP 0:INK 7
6470 FLASH 1: PRINT "Failed microdrive test": FLASH 0
6480 BEEP 10000,50
6490 STOP
6500 END IF
6510 INK 7:STRIP 0
6520 PRINT "Microdrive"!drive!"test OK"
6530 BEEP 5000,4
6540 PAUSE 100
6550 END DEFine
6560 DEFine PROCedure save_data_io
6570 OPEN#4;ser1
6580 PRINT#4;CHR$(0);CHR$(255);
6590 CLOSE#4
6600 PAUSE 50
6610 SAVE ser1
6620 END DEFine save_data_io
6630 DEFine PROCedure spin (drive)
6640 POKE 98336,3:POKE 98336,1
6650 IF drive = 2 THEN POKE 98336,2 : POKE 98336,0
6660 PAUSE 350: POKE 98336,2:POKE 98336,0
6670 IF drive = 1 THEN POKE 98336,2 : POKE 98336,0
6680 END DEFine
Great thank you, now I just have to figure out how to copy it to vdrive and run it,
Regards
Chris
Regards
Chris
Copy that text into a normal text file (not with windows standard notepad!), then copy it into an .mdv file.... oh hang on, just use this .mdv image in vDrive! Then load the SYSCOMP_BAS file.
- SYStest.zip
- (6.42 KiB) Downloaded 225 times
