Hi Guys.
I would like to find a QL SERIAL to PRINTER cable for the Sinclair "Seikosha" Printer.
Someone have a scheme for reproduce it?
Thanks and best regards.
Sinclair QL printer (Seikosha) cable
Re: Sinclair QL printer (Seikosha) cable
There are some manuals for this on Dilwyn's site :
http://www.dilwyn.me.uk/docs/manuals/in ... #qlprinter
Seems the Serial interface connections are :
RS-232C, 25-pin D male.
Pin configuration of the input connector.
PIN SIGNAL EXPLANATION
1 FG Frame Ground
3 RXD Input data
7 SG Signal Ground
20 DTR BUSY/READY state fo the printer
ON (+3 ~ +25V) … Ready to receive data
OFF (-3 ~ -25V) … Busy
so from QL - Ser1, you want these connections:
1 >>>> 1/7 on printer DB25
3 >>>> 3 on printer DB25
4 >>>> 20 on printer DB25
leave other connectors unconnected. (For serial 2 use 1, 2 and 5 instead of 1, 3 and 4)
1 FG Frame Ground
3 RXD Input data
7 SG Signal Ground
Hi,Outsoft wrote:Hi Guys.
I think I have a standard QL SER to DB25 cable.
I will check and PM you later.
Thanks for the scheme.Pr0f wrote:There are some manuals for this on Dilwyn's site :
1 FG Frame Ground
3 RXD Input data
7 SG Signal Ground
I can replicate now.
Very very kindly regards!!!
Need to use it on my German QL so DB9 to DB25 (with the same connections of the BT SER1 port on QL side).Pr0f wrote:There are some manuals for this on Dilwyn's site :
1 FG Frame Ground
3 RXD Input data
7 SG Signal Ground
Sorry for SER1 is:Pr0f wrote:There are some manuals for this on Dilwyn's site :
1 FG Frame Ground
3 RXD Input data
7 SG Signal Ground
1 >>>> 1 or 1 >>> 7 on Printer Serial DB25 port?
I need a scheme for produce a DB9 to DB25 ser1 cable for the printer.
Thanks a lot
Simon,
on the DB-25 end, 1 is "Shield" (which is normally GND) and 7 is "signal ground" (which is normally GND as well). For non-exotic applications like QL-to-printer, that is the same. So, feed 7 of the 9-pin to both 1 and 7 on the DB-25.
On second thought, shielding (the mesh around the wires) should only be connected on one end of the cable - So, if you connect the shield to the printer end (1), leave it open on the QL end and vice versa.
Thankstofro wrote:Simon,
