Posts: 2855 Joined: Sat Nov 20, 2010 7:13 pm
Post
by vanpeebles » Tue Nov 14, 2017 10:07 am
Wanted: 5.25" 1.2mb Floppy Drive, eg TEAC 55-D GFR
Cheers!
Cristian
Posts: 1024 Joined: Mon Feb 16, 2015 1:40 pm
Post
by Cristian » Tue Nov 14, 2017 1:52 pm
Post
by vanpeebles » Tue Nov 14, 2017 3:01 pm
Is it cheap?
I need to connect it to a PC, so I can write x68000 discs.
Cristian
Post
by Cristian » Tue Nov 14, 2017 5:46 pm
I would like to be sure if it's still working. I do have a couple of 5.25 floppy discs (who knows if they are still reliable?) but how to test? Should I search for a very old PC to connect the drive to? Probably also the Trumpcard will not recognise it automatically since it is set for a PC.
I'm open to suggestions
Post
by vanpeebles » Tue Nov 14, 2017 7:05 pm
See if it will format a disk and write some files to it
Cristian
Post
by Cristian » Tue Nov 14, 2017 10:52 pm
vanpeebles wrote: See if it will format a disk and write some files to it
Yes I know, but first I have to find a sufficiently old PC/OS capable of recognising the drive itself!
Post
by vanpeebles » Wed Nov 15, 2017 10:03 am
Ah!
I'm hoping the last one I have with floppy support still works!
Posts: 4824 Joined: Mon Dec 20, 2010 11:40 am
Post
by Derek_Stewart » Wed Nov 15, 2017 10:17 am
I have some old BBC Micro 5.25" 40/80 Track Floppy Disk Drives, when I get time I will see if they work and can access some of my 5.25" QL Disks.
If I made a 3.5" + 5.25" twin drive combo, in a Black Case, would this be of interest.
Post
by vanpeebles » Wed Nov 15, 2017 10:52 am
I have a BBC set off my B+ but I don't think they do 1.2mb HD discs?
Cristian
Post
by Cristian » Sun Nov 19, 2017 9:31 am
vanpeebles wrote: Ah!
I suggest you to check the BIOS config menu first. You should find something like Advanced -> Floppy configuration. Here you find a list of supported floppy drives, and you must choose 5.1/4 and the correct capacity (if present). Then is necessary that your OS can recognise such kind of drives.
