Quick and Dirty Routines for Newbies
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
If you are starting out using a QL, QL Emulator or other such hardware equivalent that uses SuperBASIC or even the coverall S*BASIC, then here are a few routines to assist you or at least get you thinking about making your own.
The absolute beauty of SuperBASIC for me is the ability to add your own commands just by simply writing procedures and functions and then you can immediately use them. TOOLKIT II is assumed to be invoked and these are routines that I use a great deal when writing programs to keep things ordered.
Saving your program as you go along with a simple S + Return
1000 DEFine PROCedure S
1010 DEV$="FLP1_"
1020 FILE$="Filename"
1030 SAVE_O DEV$&FILE$
1040 SAVE DEV$&FILE$&"_BAK"
1050 END DEFine
Getting a directory as you go along with a simple D + Return
2000 DEFine PROCedure D
2010 DEV$="FLP1_" :REMark or assume that it already exist in 'S'
2020 DIR DEV$
2030 END DEFine
Renumbering your program as you go along with a simple R + Return
3000 DEFine PROCedure R
3010 RENUM
3020 END DEFine
Quitting from your QPC2 program with a simple Q + Return, write and use with care
4000 DEFine PROCedure Q
4010 S:D
4020 QPC_EXIT
4030 END DEFine
Re: Quick and Dirty Routines for Newbies
your "S" Procedure is fine for anyone not using SMSQ/E.
Some other interesting thing is the following:
If you work with SMSQ/E you can as well simply use "SAVE" or "SAVE_O" (Without arguments). The interpreter remembers where it got the current program from and saves it in the same place. It took me a while before I realized that and so I think it makes sense to share.
Mr_Navigator
QL Fanatic
When programming stuff early on the QL, sometimes it is useful to display the character set. Here is another straight forward procedure to display the QL character set, I have deliberately made it simplistic, so newbies or re-newbies will have to adjust 10070 to suit other character sets.
10010 DEFine PROCedure char
10020 OPEN#5, scr_
10030 WINDOW#5, 512,256,0,0
10040 PAPER#5, 7:INK#5, 0
10050 CLS#5: CSIZE#5, 3,0
10060 PRINT#5, VER$
10070 FOR f=32 TO 287
10080 PRINT#5, " ";CHR$(f);
10090 NEXT f
10100 CLOSE#5
10110 END DEFine
A screen shot from Qemulator on the MAC on which it was run is available here
http://backtotheql.blogspot.com/2011/09 ... on-ql.html
qxl-kumbah
Post by qxl-kumbah »
Thanks for these routines ! :)
The save and directory program were modified slightly, since I am
using QLay and Qemulator (QLay doesn't do the SAVE_O command).
I think Qemulator does, but I haven't transferred anything that I've
been everperimenting on, to it yet.
On that note, guess I better move over to the emulation part of the forum. :)
* qxl-kumbah *
"TS-1000, Eighty-One,TS-2068, Spectrum Anywhere, QXL, QLay, and Qemulator on board"
