Using Minerva Rom with toolkit
Oggyuk
Post by Oggyuk »
Just got this Rom switcher today. using the toolkit to diagnose the problem with my QL.
Not sure what I am seeing here.
Oggyuk
Re: Using Minerva Rom with toolkit
Post by Oggyuk »
and this one
Oggyuk
Post by Oggyuk »
After numerous presses of the reset and scrolling through the above images, this comes up and then goes to the last screen.
It looks like faulty ram, those big numbers are memory address errors.
The numbers mean (from top to bottom):
  • Memory value (.L) that was written
  • Memory Value read back
  • Affected longword address
I'm, however, a bit lost why some of your pictures show read and written value as the same. The addresses seem to be QL internal memory (lower 128k), though. So, you apparently have a problem with the QL internal memory circuitry.
Oggyuk
Post by Oggyuk »
I notice it says 64k on the minerva page.
is the ram split into 2 64k banks?
The njmbers on the Minerva Ram Text screen can be input into a programme from the Minerva Utilities Disk, called "ramfail_bas". The programme will tell you which ram chip is faulty.
But only works for internal QL ram.
The support disk is available on Dilwyn's web site in the QL Roms section or direct link:
http://www.dilwyn.me.uk/qlrom/min198utils.zip
Oggyuk
Post by Oggyuk »
Er not sure how to run that file.
Is there a windows program that can interpret the numbers?
Oggyuk wrote:Er not sure how to run that file.
Well you could run the program in the free version of Q-Emulator, SMSQmulator, or QPC2.
Oggyuk
Post by Oggyuk »
Doh. of course. thanks will have a go.
