please can you help me with troubleshooting of my QL:
I have replaced:
- new cpu
- new roms
- new coprocessor
- new ULAs (both)
but the result is the same - no RGB output, just the yellow LED is lighted
What should I replace, or what shoud I measure (I have multimeters and digital osciloscope)
Thank you !
QL not working
Re: QL not working
You could put a scope on the RGB socket and see what you get on the synch pins - this will tell you if the ULA is at least producing video timing pulses.
Yellow led suggests power is getting to the board, but it won't tell you much more than that. I would take a look a the circuit diagrams / and block diagrams from the Service manual - http://www.dilwyn.me.uk/docs/manuals/QL ... Manual.pdf
Check 5v from regulator, check clock on the cpu, and check DSL lines - see if these are showing a good waveform...
Re: QL not working
Thank you for info and manual
I will check what you have mentioned.
Some quick questions - if QL is running fine (I have never owned QL so it is difficult to me):
1. what is "default screen" - the menu in which user select video output with F1,F2 keys ?
2. should the microdrives start spinning when QL is powered on ?
3. is the RGB pinout the same as is on Sinclair +2 and +3 ?
Thank you
Thank you
Re: QL not working
The RGB pinout is shown in the service guide.
It's been a while since I owned one of these, but the splash screen starts first, with the F1 / F2 prompt, and if you don't hit any keys for about 30 seconds, the screen will default to TV mode - a blue screen and pink cursor. The left hand Microdrive will usually spin briefly if there is no cartridge in it, as it's looking for a boot file.
There is a good set of tips for troubleshooting in the service manual, so it should help you along quite a way
All the best with it
Re: QL not working
Thank you again,
I will read the manual, but it will take some time
I have noticed somewhere on internet that when the QL doesn't starts it have usually 2 reasons:
1. some maybe regualtor or transistor (I don't recall exactly )
2. ULAs - but as I have mentioned I have replaced both with new one
- Aurora
Re: QL not working
You should get a screen full of coloured pixels first, then the F1/F2 splash screen. Only Minerva ROMs will auto start after about 30 seconds.Pr0f wrote:The RGB pinout is shown in the service guide.
There is a good set of tips for troubleshooting in the service manual, so it should help you along quite a wayAll the best with it
If you switch on, wait 4 or 5 seconds, then press F1 or F2. If mdv1_ spins then you have some display problem, rather than a logic problem.
Re: QL not working
No. First the startup screen should appear, then you can press F1 or F2, then Microdrive 1 will start spinning.colo wrote: 2. should the microdrives start spinning when QL is powered on ?
NO! Be careful!colo wrote: 3. is the RGB pinout the same as is on Sinclair +2 and +3 ?
