Qubata Syquest
klausfrank
Qubata Syquest
Post by klausfrank »
Hello my fellow QL’ers
Anybody out there who had tried the Syquest with the QubATA? I have tried but the QubATA can’t or won’t recognize the drive. I would be very happy with some response.
Happy QLing
Klaus
Nasta
Re: Qubata Syquest
Post by Nasta »
There must be a cartridge inside the drive for the software to recognize it as a hard disc.
klausfrank
Re: Qubata Syquest
Yes, you are right, but I have put in a cartridge formatted and by the QubIDE - it should work - but it will not!
Silvester
Re: Qubata Syquest
Post by Silvester »
Only works on Qubide v2 ROM/GAL ?
(My Iomega Zip 100mb drive required upgrade from v1.56 to V2.02 EPROM with new V2 GALs)
David
Nasta
Re: Qubata Syquest
Post by Nasta »
Yes, Syquest requires use of the alternate status register, hardware support was added in V2 GALs.
Re: Qubata Syquest
Nasta wrote:Yes, Syquest requires use of the alternate status register, hardware support was added in V2 GALs.
Hi Nasta,
Do you have the v2 GAL Code?
