The program originally executed, then just hung - nothing on screen but I could see a new no-name job in the jobs list, and so I killed it. That problem was caused by my executable, text87plus4, being completely full of CHR$(0) - Hmmm.
After restoring from my backup floppy (almost all my floppies are now dead) which is one of the ten or so that I still have left (and ripped to an image on my backups disc!) and setting the correct data space (file is 116,850 bytes, data space is 26,624) the program now simply vanishes on execution - n hangs, no jobs in the job list either.
The plus4setup program does the same - that's 40,530 bytes and the same 26,624 data space.
Having a hunt around, it seems that there's a patch required to run this application on QPC2? Does anyone know if the patch is available? Required? The best link I have is http://qlwiki.theqlforum.com/doku.php?id ... lus4_patch which indicates that it is required to run in various 16 bit colour modes, which I'm not using.
The dates of my files on the floppy are 1997 and I don't think I've used it much since then to be honest, but of course, now that I need to use it, I can't. Can someone please check if the file sizes I've given above match a working copy - thanks, I'm wondering of my floppy is corrupted somehow. I could delve in with QMON2, but life is too short sometimes!
Many thanks.
