RE: Q-Menu V 8.02 Adding oblects on QLE/QDT
simon629
Post by simon629 »
Hi can anyone help me using Q-Menu V 8.02 on QLE/QDT it will not let me ADD New Objects does anyone no how to FIX this OK Thanks simon629 Simon Foster
Re: RE: Q-Menu V 8.02 Adding oblects on QLE/QDT
This has already been covered in a previous topic - http://theqlforum.com/viewtopic.php?f=3&t=1522
The problem is a bug in QDT but we still do not have the sources to QDT, so you have to use v7 of QMenu to get around this.
Simon?
How about you tell us your story. How did you get into the QL? What do you use it for? What's your life been like?
Most of us got these things in the mid-80s and have had pretty adventurous lives.
