QL ZIP + FRONT END
Outsoft
QL ZIP + FRONT END
Post by Outsoft »
I would like to start use the ZIP format on my QL.
But I would like an easy way to zip and unzip files.
Can someone suggest me gently a good Superbasic front end (or PE too) with a zip/unzip program?
Thanks a lot.
Best regards.
Re: QL ZIP + FRONT END
The one I use is Archiver's Control Panel (ACP) which is QLIBERATED SuperBasic. Available from Dilwyn's Archives section at http://www.dilwyn.me.uk/arch/acp4e01.zip. you will need ql unzip to unzip it! That's available at http://www.dilwyn.me.uk/arch/unzip541xq.bin which is a self extracting file! Just LRESPR it and follow the prompts.
Once unzip is installed, upgrade it with this patch http://www.dilwyn.me.uk/arch/unzip541.zip and you should be good to go.
If you don't get on with ACP, Dilwyn wrote a front end for unzip which you get at http://www.dilwyn.me.uk/arch/ulib.zip.
HTH
Outsoft
Post by Outsoft »
NormanDunbar wrote:The one I use is Archiver's Control Panel (ACP) which is QLIBERATED SuperBasic. Available from Dilwyn's Archives section at http://www.dilwyn.me.uk/arch/acp4e01.zip. you will need ql unzip to unzip it! That's available at http://www.dilwyn.me.uk/arch/unzip541xq.bin which is a self extracting file! Just LRESPR it and follow the prompts.
HTH
I will try, thanks ;)
I use q-emu for unzip with headers ;)
Outsoft
Post by Outsoft »
HTH
How I can let the QLIB runtine start? I've it but I can't let start for use the other stuff.
The ULIB is working under QTrans too?
Best regards.
There is also my Zip Manager program at http://www.dilwyn.me.uk/arch/index.html, a pointer driven front end for Zip and Unzip.
It's needs Window Manager 2. Archivers Control Panel is pointer driven but doesn't need Window Manager 2, so will work better on older systems. Archivers Control Panel also handless a few other archivers like Arc, Lha, Lhq and Zoo whereas Zip Manager only handles Zip and Unzip.
I use ACP, I installed it in 1992 and still use it now.
It works with all versions of Extended Environment, allows any type of archive programme, i.e. ZIP, HAR, ARJ, LHARC etc... and when configured to be used with Fileinfo2 makes a really nice environment.
I also use Q-EMulator for extracting ZIP files as a drive.
Outsoft wrote:How I can let the QLIB runtine start? I've it but I can't let start for use the other stuff.
I hope I understand correctly what you want to do...
QLIB_RUN (and the bug fixed variants) can just be LRESPRed like other extensions.
Outsoft
Post by Outsoft »
Ok Thanks ;)
Found that I have ACP as original floppy too just preserved: all with Q-LIB runtime + Pointers (the latest version use it) so I'm watching for it, thanks.
As a FILE editor I use MASTER SPY 3.3, very strong!
Outsoft
Post by Outsoft »
Derek_Stewart wrote:Hi,
ACP outstanding: very very nice program ;)
Just tested on Q-emuL and work ok, this night I will test on SGC card ad home.
Thanks!
Outsoft
Post by Outsoft »
It works well from FLP to WIN but not from WIN to WIN or WIN to FLP
Why?
Very strange...
