I am in the process of updating a manual of QPC2 keywords, that I made some time ago.
I am having trouble finding documentation on FSEND_EVENT. I guess it's a function tied to the SEND_EVENT command.
Can anyone tell the exactly how it works, and what is it's syntax.
Thanks in advance
Martin
FSEND_EVENT
Re: FSEND_EVENT
I'd always assumed it was a function version of SEND_EVENT:Martin_Head wrote:I am in the process of updating a manual of QPC2 keywords, that I made some time ago.
Thanks in advance
Martin
As ever, if there is anything in my SMSQ/E manual you can use for this job, please feel free to use it (although I'm sure anything you produce will as ever be a hundred times better than my efforts).SEND_EVENT
The SEND_EVENT job ID, events procedure is used to notify events to another job. The job ID can be the whole number, the job number and tag or the job name.
SEND_EVENT 'fred',9 Send events 1 and 8 (1+8=9) to job fred
SEND_EVENT 20,4,8 Send event 8 to job 20, tag 4
SEND_EVENT OJOB(-1),2 Send event 2 to my owner
Online SMSQ/E manual v1.04:
http://www.dilwyn.me.uk/docs/ebooks/smsqe/SMSQE_A4.htm
or other formats available e.g. A5 layout on eBooks page.
Re: FSEND_EVENT
FSEND_EVENT is a relatively new addition to SMSQ/E - According to the release history, it has been added into 3.28 by Wolfgang Lenerz. I doubt you'll find it anywhere in the manuals because it is so new.
And, just as Dilwyn assumed, it actually is a function version of SEND_EVENT that returns an error code instead of bailing out. The only error code you can apparently get is "INVALID JOB".
Re: FSEND_EVENT
Flattery will get you everywheredilwyn wrote:As ever, if there is anything in my SMSQ/E manual you can use for this job, please feel free to use it (although I'm sure anything you produce will as ever be a hundred times better than my efforts).
