Hi
I was wondering if anyone would know how to transfer QL files to a DOM ( formated om the QL attached to the qubide) that is installed on a PC .
Neiter windows explorer nor the qlemulator see this DOM
Thanks
Vally
File tranfer to DiskOnModule
Re: File tranfer to DiskOnModule
Hi,Vally wrote:Hi
Thanks
Vally
If you can connect the DOM to a PC running WIndows, you can use the "Habi" Image Editor to read/write the QubIDE partitions.
See message thread:
http://theqlforum.com/viewtopic.php?t=16 ... 129#p17129
The Image Editor works on all Qubide removal devices.
You will have to consider the loss of QDOS Executable Headers on Executable programmes, but using Jonathan Hudson's SFX UNZIP programme this should be no problem.
