Shady component suppliers.
I ordered FIVE of an IC from an EU-based supplier, because I can be sure they have genuine stock and they're a bit cheaper after shipping than the US suppliers.
They just messaged me and said, "Our minimum order to the US is €250, so we modified your order to 149 ICs to qualify."
I replied, "You have changed the deal. I pray you do not alter it further."
It did cut the per item cost from €6.84 to €1.68 though!
