Wtd: QL Service Manual clear scan (NOT OCR!)
I need a clear scan of the QL Service Manual, October '85 or later revision.
It needs to be just a scan, not an OCR'd version. The version at http://www.dilwyn.me.uk/docs/manuals/QL ... Manual.pdf contains some critical OCR errors that, well.... :/
Would pay handsomely for an original printing with clear appendices.
Any help appreciated.
Re: Wtd: QL Service Manual clear scan (NOT OCR!)
That's the same PDF as the one I was using. It's OCR'd and a lot of the component values are WAY off. Also, the formatting's ruined. There's an HTML version that's much more correct, but it still has a few errors including some of the same values.
I just got a PM offer of a clean scan copy from an original. So, I might be okay.
RWAP wrote:What about the one on WOS - http://www.worldofspectrum.org/pub/sinc ... Manual.pdf
Hi Rich,
This version is the same as the Service Manual I have, except, my manual is an original.
I can scan this if required.
Tony Fiershman did some corrections to the QL Circuit diagrams, I will see if I have the details of the corrections.
I received what I was looking for in the mail this morning. Thank you!
