SMSQzine #4
swensont
SMSQzine #4
Post by swensont »
I've just posted SMSQzine #4 on my Google Sites page: https://sites.google.com/site/svenqhj/home/
Look for smsqzine04.pdf and smsqzine04.zip
Tim Swenson
Re: SMSQzine #4
Cool stuff, thanks Tim. Regarding COLOUR_QL, etc. this mode switching is a purely internal SBasic concept. The other colour modes are implemented by different TRAPs from the QL colour TRAPs, so by setting COLOUR_24 you just tell the basic commands like PAPER to use the 24-bit TRAP instead. Usually a bit of assembler is needed to interface TRAPs to the C compiler, but this way you should be able to make your own paper24 function, for example.
Cheers, Marcel
