DIY-Toolkit EDLINE$() function - improved version
ql_freak
Post by ql_freak »
On the English download page of my homepage you now will find an improved version for this nice function:
If called with 3 parameters (no defaults for the first three parameters, as in original version) it behaves as the original DIY-TK function (i.e. existing code should not be broken): Only ENTER allowed for terminating editing, the string is returned without the terminating character. I have added a fourth, optional parameter. Only the first four bits are used, and at least one bit must be set. I.e. range is from 1 to 15 - this is checked, if outside you get a bad parameter error (I should correct this to out of range).
Bit set    Terminating key allowed
0            ENTER (10)
1            ESC (27) (Only on Minerva and some SMS versions)
2            Arrow (cursor) Up (208)
4            Arrow (cursor) Down (216)
When used with the 4th parameter, the terminating character is the last character of the returned string and must normally be stripped. Therefore 2 support functions are included in the toolkit:
lastChar=EDLINEL(string$) returns the character code of the last character in a string or -1 for a zero length string
humanString$=EDLIN$(string$) strips the last character of string$ and returns it. For a zero length string, a zero length string is returned.
Should I rename the 2 support functions (in fact EDLINEL() returns an int)?
Here an example how you can use it:
1000 REMark Test for improved EDLINE$(...)-FuNction from hps
1040 :
1080 DIM field$(3,22)
1120 field$(0)="Field1":field$(1)="Field2":field$(2)="Field3":field$(3)="Field4"
1160 CLS#1
1200 PRINT#1,"ENTER accepts all input fields"
1240 PRINT#1,"ESC restores current input field"
1280 PRINT#1,"Cursor Up/Down to select field"
1320 FOR inln=0 TO DIMN(field$):PRINT field$(inln)
1360 inln=0
1400 REPeat inloop
1440   SELect ON inln
1480   ON inln=0
1530     AT#1,3+inln,0
1560     fld$=EDLINE$(#1,21,field$(inln),1+2+8):REMark ENTER+ESC+CrsDown
1840   ON inln=1TO DIMN(field$)-1
1880     AT#1,3+inln,0
1920     fld$=EDLINE$(#1,21,field$(inln),15):REMark ENTER+ESC+CrsDown+CrsUp
2240   ON inln=DIMN(field$)
2280     AT#1,3+inln,0:fld$=EDLINE$(#1,21,field$(inln),1+2+4):REMark ENTER+ESC+CrsUp
2520   END SELect
2570   last=EDLINEL(fld$)
2600   IF last=27:NEXT inloop
2650   field$(inln)=EDLIN$(fld$)
2680   SELect ON last
2720   ON last=10
2760     EXIT inloop
2800   ON last=216
2840     inln=inln+1
2880   ON last=208
2920     inln=inln-1
2960   END SELect
3000 END REPeat inloop
3040 AT#1,8,0
3050 PRINT"User Input:"
3080 FOR inln=0 TO 3
3120   PRINT field$(inln)
3160 END FOR inln
ql_freak
Re: DIY-Toolkit EDLINE$() function - improved version
Post by ql_freak »
EDLINE$() now tested on Minerva 1.98 with uQLx on Windows with WSL.
Seems to work.
