Gold Card and JM ROM?
mhanias
Brittle Membrane
Post by mhanias »
I want to report a problem with a QL JM rom with Gold card and ICE.
The Ql boots but it passes the first screen with F1 for monitor and F2
for TV and goes to ICE screen then with quit it goes to monitor screen
The same happens without ICE.
With mode 8 or wtv gives back the TV screen .
The Ql works fine without GG. I removed the 68008 but the problem did not sollved
Is it a bad combination of GG and JM Rom?
Thanks
Michael
Re: Gold Card and JM ROM?
I should add that I have already been speaking with the user about this - he has tried removing the 68008 from the QL, but that does not resolve the issue.
The Gold Card works fine with a JS ROM QL.
I have also suggested that he check that none of the expansion port pins are bent or missing as it could be the lack of a vital signal to the Gold Card.
I also suggested that he check that the machine is not fitted with a QPower regulator - just a standard QL power regulator and heatsink.
Any other suggestions?
The other thing would be to swap over the JM ROMs for the JS ROMs and see if the machine then works, as that would eliminate the hardware!
mhanias
Brittle Membrane
Post by mhanias »
I have check the pins . They are ok Also I renew the regulator with a 78S05. I wiil try with JS Rom
I tested my trump card and it works fine
