MAME QL Emulation
MAME QL Emulation
So MESS merged with MAME so MAME has QL emulation
To save you the trouble of tracking down the correct files for romdir in mame for QL + trumpcard emulation here they are in one zip.
https://dl.dropboxusercontent.com/u/9750127/ql-mame.zip
Trump 512k is the biggest memory configuration that works, the 768k option just locks up.
And obligatory screenshot of mame running Psion software :-D
ImageMAME by XorA, on Flickr
Cristian
Re: MAME QL Emulation
Post by Cristian »
MAME rules! :)
HullQLMan
Post by HullQLMan »
Hi
I've download both MAME and ql-mame and unpacked/unzipped them into separate folders. Do the ql-mame files have to be copied into the MAME folders and if so which ones go where?
That depends on the type of mame and mameui you downloaded.
Basically just unzip the ql-mame.zip into the romdir (should be defined in your UI)
inside the romdir all the paths are correct.
G
