Icicle by Eidersoft
Icicle by Eidersoft
Does anyone have the ICE package, and in particular Icicle by EIdersoft?
I have just tried running Icicle under q-emulator, but it throws up various window error boxes - so I need to check if it is my copy or a bug in q-emulator!
Re: Icicle by Eidersoft
Hi Rich,
I have emailed you a copy of all the ICE software.
I can only get the ICE Rom running as a Main Rom and Toolkit 2 as a Back ROM.
DId not work very well.
I did start to disassemble the ICE rom a while back, as with an update could give a windowing system on a 128K QL.
Thanks Derek - looks to be the same versions of the software which I have already unfortunately - it is looking more than likely it is a bug in q-emulator - did you try launching Icicle?
Hi Rich,
I was able to run Basic_Icicle by EXECing the file as shown here:
OK that is weird - admittedly I didn't link in Toolkit II - but had the ICE ROM linked in.
Mine starts drawing the outlines of the buttons / icons and then throws all sorts of errors.
What version is your q-emulator?
RWAP wrote:OK that is weird - admittedly I didn't link in Toolkit II - but had the ICE ROM linked in.
V3.1.3
OK - it works on v3.1.4 - you MUST ensure that the ICE ROM is loaded as the BACK ROM.
HI Rich,
I had assumed that the ICE rom file was loaded as a Back Rom.
I see you have a later version of QEMulator, do you what the changes are?
Unfortunately, no I don't know what the changes are - it is the latest version on Daniele's website....
AnnaWu
Post by AnnaWu »
Version 3.1.4
- Fixed crash at shutdown on Windows 7/8 when running the executable directly from a DVD rather than running the installer.
- Fixed issue where entering the debugger after a QL program exception would always stop at the interrupt 2 service routine address.
http://terdina.net/ql/VersionHistory.html
