RGB to VGA upscaler for the QL
Hi to all guys.
I would like to put a second QL postation here in my office for make more fastly the dumps.
But here I've only VGA monitors, so I would like to know If someone can suggest me a good RGB to VGA upscaler.
I simply need to put the QL from his RGB in a 1024x768 resolution on a old 15" TFT monitor.
Thanks a lot for the help.
Best regards.
Best regards.
Re: RGB to VGA upscaler for the QL
Simone,
the cheap GBS-8220 RGB to VGA converters you get on eBay work quite well.
http://theqlforum.com/viewtopic.php?f=2&t=12&hilit=8220
ehm...I would like to find something that can accept a scart connection, is it possible?tofro wrote:Simone,
SCART from the QL? Well, you'd need to solder a cable, then. The GBS-8220 wants R, G, B and composite sync from the QL.
Yes it is possible. For example SCART to HDMI.Outsoft wrote:ehm...I would like to find something that can accept a scart connection, is it possible?tofro wrote:Simone,
https://www.amazon.it/Scart-HDMI-HDMI-1 ... nvertitore
Not so cheap but a good investment as you can use it also for a number of other retro-computers (I use it also for Amiga, ST, Electron, C64, etc.).
Real QL beginner
yes dear, is the same I use on my QL right nowcercamon wrote:Yes it is possible. For example SCART to HDMI.Outsoft wrote:ehm...I would like to find something that can accept a scart connection, is it possible?tofro wrote:Simone,
Just need to use it one at my office with a VGA monitor ^_^
I think is better to use a TV with HDMI too.
I guess that you already had a look at this:
http://www.dilwyn.me.uk/docs/hardware/ql2vga.pdf
The first part includes a SCART to VGA adapter.
Real QL beginner
Thanks dear!cercamon wrote:I guess that you already had a look at this:
The site is down, the Cart to Vga converter is exactly what I need
This is the one:
http://www.js-technology.com/store/prod ... product=12
Real QL beginner
Thanks dearcercamon wrote:This is the one:
