I have games which are currently saved from within q-emulator into Windows folders and run well.
However, if a Linux user wants to play one of these games - what is the best method to supply them?
Does uQLx support a disk image for example?
Getting QL files onto Linux
Re: Getting QL files onto Linux
QPC2 runs very well using WINE on Linux and can use floppy images.
uqlx does support both real QDOS floppies (in case the user still has a drive) and floppy disk images (simple device dumps which can be created using rawrite, for example)
.uqlxrc:
makes flp1_ using a disk image named flp-image in the user's home directory and flp2_ the first real 720k drive.
.uqlxrc:
DEVICE = flp1,~/disks/flp-image,qdos-fs
DEVICE = flp2_,dev/fd0h720,qdos-fs
OK - I will create a floppy disk image in q-emulator and copy the files to that.
They can then load the programs from uqlx, so that makes it easy - thanks
- Derek_Stewart
Why not use a QXL.WIN file and use QPC2, SMSQmulator, QEMulator with Wine under Linux, this what I do.
I quite like the NFA device on SMSQmulator, so that a downloaded file can be unzipped from SMSQ/E in the native file system without loss of file header or excutable header.
If you use QPC2_QLSCREMU command in QPC2, most games may run.
