.. in the SMSQE version 3.26, how it works?
iv'e not found documentation.... (probably my fault)
Giorgio
the new ALPHA_BLEND command
- Giorgio Garabello
- Gold Card
Re: the new ALPHA_BLEND command
Giorgio Garabello wrote:.. in the SMSQE version 3.26, how it works?
Giorgio
Hi Giorgio,
I updated the SMSQ/QDOS Reference Manual, with the information you need, it can be found at:
http://www.wlenerz.com/QLStuff/#qdosms
- Giorgio Garabello
- Gold Card
thnks!
Quantum Technology
When I get time I will update the SMSQE/SBASIC manual, as it needs the addition of the Alpha_Blend keyword and Recent thing (time... at least Derek has already managed to update the SMSQE Reference Guide).Giorgio Garabello wrote:.. in the SMSQE version 3.26, how it works?
Giorgio
Here's a short extract from the current Quanta mag where I described the Alpha_Blend:
Alpha-blending is a method of drawing graphics whereby the resultant output is partly transparent – overlapping shapes and text created with BLOCK, LINE, CIRCLE, PRINT etc. will be see-through to a degree, set by a new command ALPHA_BLEND. This takes a value from 0 (fully transparent) to 255 (opaque), ALPHA_BLEND 128 will make all output half-transparent, for example.
In the past, we have only had the variations offered by the OVER command, now we can achieve some pretty exciting graphical effects for use in games, for example. Here’s a sample screen shot showing the results from Marcel’s short BASIC program which draws three overlapping circles which are half-transparent.
In the screen shot, the circle is seen beneath, through the ones above, and the text printed is also partly transparent. By varying the ALPHA_BLEND value in line 20 you can see how adjusting the ALPHA_BLEND parameter varies the degree of transparency.
A new trap #3 with D0=$62, d1=alpha weight 0-255, d3.w=timeout and a0=channel ID allows the alpha-blend value to be set from assembler and other languages.
Now someone just needs to add this to the SBASIC/SuperBASIC Online Manual...
- NormanDunbar
- Forum Moderator
As no-one else did, I did!RWAP wrote:Now someone just needs to add this to the SBASIC/SuperBASIC Online Manual...
https://superbasic-manual.readthedocs.i ... lpha-blend
Of course, until I get my finger out and build a easy to use manual updater, I'm pretty much the only one who can update the docs!
Thanks Norman, it's been in the SMSQ/E manual since v1.04 too.
For the record, if you discover any further new SBASIC keywords to be added, if I've updated the SMSQ/E manual before it's added to the online reference guide, feel free to copy, or to point out any errors/omissions I may have made!
- NormanDunbar
- Forum Moderator
Thanks Dilwyn.
And thanks for the original details of the ALPHA_BLEND command.
