bitwise operators
flinx
bitwise operators
Post by flinx »
Hello.
I've neglected the QL for too many years, and now I'm lost. (Also, I'm old and don't speak English very well: a very bad combo).
Enter 'The Question': I remember that in SuperBasic exists bitwise operators: && (AND) ^^ (XOR) and || (OR). But there is, in SuperBasic, the equivalent bitwise operator for NOT (~~)?
If I try
PRINT ~~value1 (edited, this is the correct form - in C - for bitwise not)
the result is a parser error (bad line).
Bitwise NOT can be implemented via SuperBasic extension, obviously. But I try to not reinvent the wheel.
Someone can help? Thanks in advance.
Emiliano (a.k.a. Flinx)
I'm an old boy from Italy. Please be kind with my spelling ;)
Re: bitwise operators
You were close:
NOT is the "logical" NOT operator
~ (single tilde) is the "binary" NOT operator (according to the QPC concepts guide, and that is wrong)
~~ is the right one....
ppe
Post by ppe »
Hi Emiliano,
just tested on my JS ROM. Tried this:
PRINT ~~12
and got the answer -13
So, the classic non-helpful "works on my machine" answer.... :)
Best regards,
Petri
Apparently, bitwise operators work on integer variables only in the original QDOS.
SMSQ/E accepts floating point numbers (and converts them to 32-bit longs before applying the operator)
So working/non working can very well depend on the value you tried.
flinx
Post by flinx »
Many thanks to you all. The error was mine, and very stupid: I use Q-emulator, and to input the tilde char I was typing ALT+5 combination . I don't know why, but that does not work. If I copy the tilde from PETRI example: voilà, it works.
Ok, time to resume my old QL ... :-)
Again, thanks to all.
Emiliano
