Launchpad Difficulties
lowrybt
Post by lowrybt »
Hello and thanks to any who can help....
I'm trying out Launchpad v2 demo for the first time, using Q-Emulator on OSX and running into difficulties.
Using the JS ROM with TK2. Emulator set to 640K. Normal QL speed.
First issue: when I run the Config program that came with the Launchpad demo files, the emulator appears to get caught in an unbreakable loop, with the screen refreshing over and over. Never get to any kind of configuration or setup screen.
Any suggestions on how to get Config to run as it should?
Thanks,
Tom
EmmBee
Re: Launchpad Difficulties
Post by EmmBee »
Hi lowrybt,
I can only suggest you try with more memory.
Kind regards,
EmmBee
