Keymap table
MIST
Keymap table
Post by MIST »
While working on the HDL QL i had to understand the keyboard encoding. Here it is.
Sinclair QL keycode table       Till Harbaum            V1.0 - 08/04/2015
This table shows how the 64 keys of the Sinclair QL are wired and how their
codes on IPC cmd 8 and 9 are derived.
http://www.sinclairql.net/srv/keyboard_format.png
Example
E.g. pressing the Q key on a UK keyboard connects Pin 2 of J11 with Pin 4 of
J12. This is the key in row 1 and column 3. On IPC command 8 the 8049 will
respond with $0b for this key (8*1+3 = 11 = $0b). A Command 9 request for
row 6 will return 8 (2^3 = 8).
+------------------- row (request to cmd 9 is 7-row)
|  +---------------- J11 (pin connected to J12 when pressed)
|  |  +------------- column (reply to cmd 9 is 2^column)
|  |  |  +---------- J12 (pin connected to J11 when pressed)
|  |  |  |  +------- keycode returned by IPC Command 8 (= 8*row+column)
|  |  |  |  |     +- key label on UK keyboard
   9     1        CTRL, reported in bit 1 of cmd 8 modifier bits
   9     2        SHIFT, reported in bit 2 of cmd 8 modifier bits
   9    11        ALT, reported in bit 0 of cmd 8 modifier bits
0  7  0  9        <unused> SHIFT is mapped here in cmd 9 reply
0  7  1  3        <unused> CTRL is mapped here in cmd 9 reply
0  7  2  7        <unused> ALT is mapped here in cmd 9 reply
0  7  3  4 03     x
0  7  4  5 04     v
0  7  5 10 05     /
0  7  6  6 06     n
0  7  7  8 07     ,
1  2  0  9 08     8
1  2  1  3 09     2
1  2  2  7 0A     6
1  2  3  4 0B     q
1  2  4  5 0C     e
1  2  5 10 0D     0
1  2  6  6 0E     t
1  2  7  8 0F     u
2  3  0  9 10     9
2  3  1  3 11     w
2  3  2  7 12     i
2  3  3  4 13     TAB
2  3  4  5 14     r
2  3  5 10 15     -
2  3  6  6 16     y
2  3  7  8 17     o
3  4  0  9 18     l
3  4  1  3 19     3
3  4  2  7 1A     h
3  4  3  4 1B     1
3  4  4  5 1C     a
3  4  5 10 1D     p
3  4  6  6 1E     d
3  4  7  8 1F     j
4  5  0  9 20     [
4  5  1  3 21     CAPS
4  5  2  7 22     k
4  5  3  4 23     s
4  5  4  5 24     f
4  5  5 10 25     =
4  5  6  6 26     g
4  5  7  8 27     ;
5  6  0  9 28     ]
5  6  1  3 29     z
5  6  2  7 2A     .
5  6  3  4 2B     c
5  6  4  5 2C     b
5  6  5 10 2D     Pound
5  6  6  6 2E     m
5  6  7  8 2F     '
6  8  0  9 30     RET
6  8  1  3 31     Left
6  8  2  7 32     Up
6  8  3  4 33     ESC
6  8  4  5 34     Right
6  8  5 10 35     \
6  8  6  6 36     SPACE
6  8  7  8 37     Down
7  1  0  9 38     F4
7  1  1  3 39     F1
7  1  2  7 3A     5
7  1  3  4 3B     F2
7  1  4  5 3C     F3
7  1  5 10 3D     F5
7  1  6  6 3E     4
7  1  7  8 3F     7
Cristian
Re: Keymap table
Post by Cristian »
Interesting
