QL Monitor Lead
QL Monitor Lead
Does anyone know what monitor had a 9 pin D socket connection on it for the RGB signal from the QL - see picture
Re: QL Monitor Lead
Rich,
EGA monitors used to have 9-Pin D-Subs on them.
chriskgnr
Brittle Membrane
Re: QL Monitor Lead
Post by chriskgnr »
or maybe a Commodore 1083s, like the one i use! :D
Re: QL Monitor Lead
Ah right - I have only ever seen the DIN sockets and SCART like connectors
If anyone wants the lead feel free to give me a shout!
Re: QL Monitor Lead
Hi Rich,
I have a CM8833 MkII Monitor, which may this type of monitor lead.
1024MAK
Re: QL Monitor Lead
Post by 1024MAK »
There were some multi sync CRT monitors that also had 9 pin D connectors (for EGA and VGA modes).
Mark
:!: Standby alert :!:
“There are four lights!”
Re: QL Monitor Lead
RWAP wrote:Does anyone know what monitor had a 9 pin D socket connection on it for the RGB signal from the QL - see picture
Hi Rich,
I have to make a QL monitor lead for my CM11342 aka CM833-II
According to the monitor manual, the 9 pin D connector on the rear of the monitor accepts Analog and TTL RGB.
Your lead maybe for this type of monitor.
I will construct the lead and report back.
