I seem to remember there was some code that should be included in addon ROMS, because JM & before stop scanning after the first addon ROM.
Does anyone have the code snippet or pointers to it ?
Cheers.
Phill.
ROM header
Re: ROM header
QDOS Companion (Andrew Pennell) page 138, 'Peripheral ROM Problem' section.prime wrote:I seem to remember there was some code that should be included in addon ROMS, because JM & before stop scanning after the first addon ROM.
Cheers.
Phill.
External ROMs and Device Drivers
(from QDOS Companion, Chapter 9)
The QL hardware and firmware has been designed for expansion with additional hardware, in the
form of external ROMs which may also include extra hardware for peripherals. All extra ROMs have a
defined format, so that the QL can recognise them and take action on finding them. There are two
areas in which additional ROMs can lie — in the ROM socket at $0C000, or in a peripheral ROM from
$C0000 to $FC000 in 16K blocks.
The ROM socket
This can accommodate up to 16K of ROM, and plugs in via the socket on the back of the QL. In the
address map it always lies from $OC000 to $OFFFF, and is thus the only place in the memory map
that user-written routines can be position dependent.
The peripheral ROMs
Up to 16 peripheral ROMs of 16K each can be added to the QL, though if more than one is added
then an additional board, such as the expansion module, is required. As such ROMs can lie anywhere
within the memory map, all code within them has to be position independent. They connect via the
expansion bus on the left of the QL and can contain ROM, RAM or any other I/O devices, though they
must start with ROM for the system to recognise them.
ROM Header Format
To tell if a ROM is connected or not, the system looks for a specific pattern in it, thus:
START DC.L $4AFB0001 ; identification word
DC.W BASPROCS-START ; start of proc/fn definitions (or 0)
DC.W INIT-START ; initialisation routine (or 0)
DC.W NAMELEN ; length of ROM name
DC.B “ROM name”,10 ; the name itself + LF
BASPROCS should be a list of SuperBASIC procedures and functions to be added to the system, as
per usual QDOS documentation for BASIC extensions, or 0 if there are none to be aded. INIT should
point to the initialisation routine called after power-up, or 0 if one is not required. The INIT routine will
be executed in user mode, and if a successful return to QDOS is required then registers A0 (zero), A3
(points to the start of the ROM) and A6 ($28000) should not be altered. When INIT is called, the
system tables and BASIC have been set up, but channel 0 is the only channel open. Other channels
should not be opened by the INIT routine. Channel 0 is initially the top section of the screen, and all
ROM names found are printed in it. For this reason, they should not be longer than 36 characters and
should end in a LF character.
While this method is a very neat way of adding ROMs to the QL, there is a problem with peripheral
ROMs — in QDOS 1.03 and earlier, there is an error in the ‘look for peripherals’ routine that
terminates the search after checking for one device driver only, so other peripherals are ignored. One
way to get around this is for the INIT routine in every peripheral to see if the peripheral is the first, and
if it is then it has to carry on the search as the ROM should. This is complicated by the fact that the
patch to fix it has to work once the ROM gets corrected. Thus the INIT routine has to look something
like this:
INIT BSR NORMINIT ; call the init routine
CMP.L #$C0000,A3 ; is it the first?
BEQ.S NEXT ; if so
RTS ; it isn’t, so quit
NEXT ADD.L #$4000,A3 ; try next one
CMP.L #$100000,A3 ; at the end?
BGE.S NOMORE ; if so
* if might be a ROM so let’s see
CMP.L #$4AFB0001,(A3)
BNE NEXT ; no so do next
LEA 8(A3),A1 ; start of name
MOVE.W UT.MTEXT,A2
JSR (A2) ; print the name
MOVE.W 4(A3),D0 ; BASIC procedures and functions
BEQ.S NOBAS
LEA 0(A3,D0.W),A1
MOVE.W BP.INIT,A2
JSR (A2) ; add the procedures and functions
NOBAS MOVE.W 6(A3),D0 ; INIT routine
BEQ.S NEXT ; if none
JSR 0(A3,D0.W) ; call the INIT routine
BEQ NEXT ; get next ROM
* here when all have been done
NOMORE ADDQ.L #4,A7 ; remove return address
ADD.L #$1E,(A7) ; skip over rest of routine
RTS ; and go back to it
This fix assumes that the number of bytes taken by the erroneous routine will remain constant from
ROM to ROM. If all device drivers take similar action to the above, then there will be no need to fix the
bugs anyway, and the number of bytes will remain constant.
Note that, unlike the usual use of BP.INIT, ROM procedures and functions get added before the builtin
ones, so if there is a name clash then the external ROM version will override the usual built-in ones
