Does anyone happen to have a disassembly of the logic in the issue 6 HAL ?
Or even a fuse dump JED2EQN might be able to reverse engineer it.
Cheers.
Phill.
Issue 6 IC38
Re: Issue 6 IC38
I think I still have some here if you are just after a replacement....
Re: Issue 6 IC38
NopeRWAP wrote:I think I still have some here if you are just after a replacement....
Actually want to work out the logic....as it's combinational, it should be possible to step through all the inputs (with a microcontroller for example), record all the outputs and then build up a truth table which should reveal the logic....
But if someone had already done that, would have saved me the effort
Cheers.
Phill.
