IPC clock.....
prime
IPC clock.....
Post by prime »
Hi all,
I tried searching the 8048 datasheet and either missed it or it isn't there......
The 8048 / 8049 IPC in the QL operates from an 11MHz crystal, but does anyone know what the relationship between clock cycles and instruction rate / machine cycles is ? I know that for the 8080 (and derivatives such as the Z80) the ratio is generally one machine cycle per 4 clock cycles.
Anyone know what the correct figure for the 8048 is ?
Cheers.
Phill.
1024MAK
Re: IPC clock.....
Post by 1024MAK »
Does the information in this Wikipedia entry help ?
See pages 13 and 14 of this document MCS-48 family architecture pdf
Mark
:!: Standby alert :!:
“There are four lights!”
prime
Re: IPC clock.....
Post by prime »
Cheers Mark,
That's exactly what i needed.
Looking at that, the machine cycle of the IPC is 1/ (11MHz/3) = 272ns.
So in the keyboard read routine :
05C8: 39      OUTL P1,A       output A on P1
05C9: AB      MOV  R3,A
05CA: 80      MOVX A,@R0      put P0 in read mode=HI-Z ??
05CB: 00      NOP             wait a bit
05CC: 00      NOP
05CD: 00      NOP
05CE: 00      NOP
05CF: 00      NOP
05D0: 00      NOP
05D1: 08      IN   A,P0       get P0 into A
05D2: 93      RETR
It looks like I have about 2.72us between the out and the in if I where wanting to drive the keyboard lines externally with a microcontroller.
Cheers.
Phill.
Re: IPC clock.....
When not look at the 8049 disassembly, which is located in the Disassembly Section on Dilwyn's web site or QL Today DVD.
Nasta
Re: IPC clock.....
Post by Nasta »
prime wrote:Cheers Mark,
Careful with that. The 8048 clock is divided by 3 from the crystal, but each cycle takes 4 clocks, so it's effectively 11MHz/12
