RWAP Software - Summer Stock Clearance
Sell your QL items here!
I have listed some second hand QLs and microdrive units on sellmyretro - I will upload some pictures later.
Basically, the QLs are untested except to check that they power up and provide an output on my monitor.
Supplied without leads / power supplies etc - so ideal for spare parts and/or refurbishment.
£40 each
See:
http://www.sellmyretro.com/offer/detail ... ly%29-3805
The Microdrive units are ones I have pulled from QLs - I use them myself to replace non-working microdrives, so over the years, most of the ones I have left are working but may need new rollers (the non-working ones have been thrown away as I go through the box to find a working replacement).
See:
http://www.sellmyretro.com/offer/detail ... Units-3806
prime
Re: RWAP Software - Summer Stock Clearance
Post by prime »
You don't happen to have a dead motherboard, doesn't have to have any of the removable chips on, would be useful for aligning and measuring that internal boards fit....
Cheers.
Phill.
I will have to see what turns up :)
I have about 20 QLs here - it is only when I go to use one I find out if it is still working or not - I had a load of motherboards repaired recently, hence the stock clearance of the repaired machines
Does anyone want a QL User Guide (the big ring bound ones supplied with the QL) - I have several here - £2 each plus postage...
I have a couple of non-working QL motherboards - available for £10 each ( socketed chips removed) - add £5 if you want a case bottom, plus postage of course
I also now have an EU2000 power supply - oddly the main lead is one for a Spectrum +128 (I guess) - someone has also made a hole in the other side and attached a QL lead to that side.
Makes a loud buzz when in use
£5 plus postage - if someone just wants the QL power lead, let me know and I will unsolder it - same price (although a lot cheaper postage) as I will throw the power supply out.
Paul
Post by Paul »
I would like to buy the power supply and a broken QL.
PM sent.
Paul
