QL-SD
QL-SD
When is the next batch of QL-SD likely to be made available, please?
(I had an email asking when).
Re: QL-SD
Did the second batch sell out on sellmyretro? :)
Paul
Re: QL-SD
Post by Paul »
They didn't sell out.
So there are still some QLSD available. I stopped auto relisting because of holidays.
There will be a relisting in about four weeks on SMR
Kind regards
Paul
Re: QL-SD
Paul wrote:They didn't sell out.
Kind regards
Paul
Thank you. I will pass your reply on to the person who asked.
Re: QL-SD
As QL-SD related posts have spread into several therads, I was trying to search for "QL-SD".
But get the message:
"No posts were found because the word ql-sd is not contained in any post."
Is it possible to search for the term "QL-SD"?
1024MAK
Re: QL-SD
Post by 1024MAK »
Type
site:http://www.theqlforum.com/ QL-SD
into a Google search box ;)
(Other search engines are available, your mileage may vary, batteries not included, may contain small machine code parts).
Mark
:!: Standby alert :!:
“There are four lights!”
Re: QL-SD
Thanks. Looks like Google can do more off-site these days, than most websites can do internally.
Marq
Re: QL-SD
Post by Marq »
Finally installed mine on a plain QL and seems to work fine even if the configuration seems to be mildly deprecated. Finally I can start the file transfer host automatically without d*cking with those nerve wracking microdrives that just kept eating the remaining few tapes :) Great! Hoping to do some coding on the platform again.
Paul
Re: QL-SD
Post by Paul »
Kind regards
Paul
Here you are:
http://www.sellmyretro.com/offer/detail ... or-QL-3703
Marq
Re: QL-SD
Post by Marq »
Is there some sort of documentation for the QL-SD .bin files, by the way? Would be handy to distribute files as ready-made images with all the required bits so that others wouldn't need to bother transferring files themselves.
