Embedded Power Supply for QL
Sell your QL items here!
I have listed for sale some very nice embedded power supplies suitable for re-cased QL systems.
I am charging $49.99 - £29.75 - 36.15€ plus my usual flat rate shipping of £2 - 2.38€. All proceeds benefit the QL hardware development fund. I have a quantity of these, new old stock, and they allow QL backplane systems to be put in much smaller cases.
Detailed description: A tiny embedded switch mode power supply with a high capacity and high efficientcy for low heat output. Measuting only 102 x 51 x 25mm (4" x 2" x 1") they can deliver 5V @ 8A, 12V @3A and -12V @ 0.5A. Comes with an IEC panel mount socket, switch, and power cable with standard 4-pin header for a QL backplane, plus a 6 pin header. Also included are four self-adhesive stand-offs to make mounting the PCB in any enclosure very easy. New old stock with one year warranty and full instructions.
http://sinclairql.com/store/index.php?r ... duct_id=61
aisling42
Re: Embedded Power Supply for QL
Post by aisling42 »
Dave wrote:I have listed for sale some very nice embedded power supplies suitable for re-cased QL systems.
I'm not sure from the description whether this will go in a Black Box. I figured no, but the blurb seems to say simultaneously "any re-cased QL" and yet "any enclosure."
If this embedded PS will go in a Black Box, it would make sense to get it instead of an old 80s "bit of kit".
If it doesn't fit in a Black Box, w/o modification, let's please stick with sending the "old" PS we talked about. I will then be able to test the floppy cables Derek has sent (and I haven't paid for yet :-( as he requested I test the cables first, even though I think I should pay regardless, esp with hanging onto them so long :-) ).
Thanks Dave,
Doug
The embedded supplies I have are not suited to go inside a black box QL case.
I'll continue with plan A.
