QL Emulation in Mess
prime
Post by prime »
Hi all,
After hacking disk support into Mess a couple of years back, which actually made it mostly usable, though it still doesn't support microdrives :(
I've now (hopefully) fixed the IPC communication code so that making a sound doesn't crash the machine, which makes it more usable. It works well enough that I can play QL Cavern which I couldn't before.
I'll submit the patches on the MAME / MESS development list so they should be in the next point release.
Cheers.
Phill.
prime
Re: QL Emulation in Mess
Post by prime »
And my latest working version has QIMI support so you can use the pointer environment with a mouse :)
Cheers.
Phill.
prime wrote:And my latest working version has QIMI support so you can use the pointer environment with a mouse :)
Cheers.
Phill.
Great news. I keep meaning to go back to try the MESS QL emulator after the work you've put into it the last couple of years... if only I had the time!
nitrofurano
Post by nitrofurano »
after 8 years i think it's not a problem bringing this thread to live back again... xD
i'm actually trying to run QL emulation on mame/mess - it seems to run close to fine from what i expected
in the mame(mess file manager, we find magtape1 (magt1), magtape2 (magt2), and cartridge (cart) - i though that was supposed magt would open .mdv files, but it didn't recognize any from what i tried - i also have no idea which rom files could be tried as cart
i don't know if anyone here have tried ql emulation mame/mess since then
nitrofurano wrote:after 8 years i think it's not a problem bringing this thread to live back again... xD
MDV support is completely missing.
Cart is things like the TK2 rom.
Best is to add a 512K Trump Card then add a floppy disk! (768k trump does not work)
