Verify on Copy
- ROM Dongle
Verify on Copy
I've not come across a verify option on the copy/wcopy command as there is commonly on PC. Is there one?
Re: Verify on Copy
Unfortunately, not - however, toolkit 2 based disk interfaces should warn you with bad or changed medium.
If you are looking to copy files from microdrive cartridge, the best bet is to use the built in feature of the QJump RAM disk to make a sector copy to ram disk - see http://www.theqlforum.com/viewtopic.php? ... 1_mdv1#p95
