QL Wishlist for 2014
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
Remember this ? (for forum people who have been here awhile)
Well not so much a wish now. It came today! :)
Thoughts and pics of the new SD interface in the QUANTA feb/mar issue
But what else could we wish for this year hmmmnnn
Sparrowhawk
Re: QL Wishlist for 2014
Post by Sparrowhawk »
Mmmmm... SD card interface - Nice! :) Once the issue is published, would you mind summing up here too for us non-Quanta members?
As for me, I'd still like to see SQlite ported with SuperBASIC extensions. I know it won't happen (and I don't have the C and QDOS/68008 skills needed to make it happen either), but it would make porting over loads of my software so much easier if there were an SQL-based relational database available on the QL. (I know that there are other database systems for the QL, but non are SQL-based, to my knowledge and as such tend to be rather unwieldy)
Maybe a Raspberry Pi distro that booted straight into a QL emulator, no faffing about, would be a nice addition to my current collection of RaspPi operating systems.
Hardware-wise, I am more just interested to see what people come up with, as I just use emulators now and keep my original in a box.
And... a QL mug! The QL seems to be the only mainstream 80s micro not to have its own mug on eBay. For shame :D
a.k.a. Jean-Yves
I did have a look at the SQLite3 source code, a wulie back.
SQLite3 uses Unicode in its compilation. I was pondering over, does the QL system needs Unicode. I do not think there is a Unicode Library for C68, so maybe porting SQLite without Unicode would be OK.
This as a while back, I was overtaken by more pressing things, however, since I am not working anymore, maybe I could look at this again.
Mr_Navigator
QL Fanatic
Sparrowhawk wrote:Mmmmm... SD card interface - Nice! :) Once the issue is published, would you mind summing up here too for us non-Quanta members?
Sure, absolutely, however I may not have it set-up until I get my set-up unpacked
This is on my ever list of things to complete, I say complete rather than do as I am already halfway there, moving is taking its toll at the mo :(
Both for me
Mug, QL mug - pic please
That first image is interesting, as it shows the QL-SD in the left hand microdrive slot... I wonder if the right hand slot still works, because it seems you need to add a wire link if you remove mdv1 !!
Mr_Navigator
QL Fanatic
RWAP wrote:That first image is interesting, as it shows the QL-SD in the left hand microdrive slot... I wonder if the right hand slot still works, because it seems you need to add a wire link if you remove mdv1 !!
Ah that was from a wishlist in 2011 where I did some gigury pokery with Photoshop
Sparrowhawk
Derek_Stewart wrote:since I am not working anymore, maybe I could look at this again.
That would be great if you were able to do so. Count me in as a system tester if you like.
a.k.a. Jean-Yves
Silvester
Post by Silvester »
Just finished learning Python (on Ubuntu laptop, to have a programming language to use on it). One of the things it covered was using SQLite, I thought wouldn't this be great on the QL... This is definitely on my wish list also (along with TCP/IP access like Python).
David
