Metacomco (or other) assembler in MDV format
gertk
Hardware Hero
Post by gertk »
I am looking for a MDV image of the Metacomco Assembler for the QL
It was the only MD tape I carefully kept for years but it has died (tape damaged, pad gone).
Also is there some Linux/Dos/Win tool to generate MDV images from a bunch of files ?
Re: Metacomco (or other) assembler in MDV format
Gert,
depends a bit on what you think a "Microdrive Image" might be - Is that the same format that QEMulator and QLay use?
If yes, then qlayt is your friend (and no need to fetch it from a faraway place ;) )
http://web.inter.nl.net/hcc/A.Jaw.Venema/qlayt090.zip
This should be able to copy files into Q-Emulator-compatible mdv images.
If you can send me some proof of ownership (by email), I will send you the necessary files - I can't remember if q-emulator can save to microdrive image files (I don't think so), but I can let you have them as a QL Zip if that is any good?
Sparrowhawk
Post by Sparrowhawk »
Forgive me for jumping in here chaps, but as this is related:
Rich, would you be able to provide me with a copy of Assembler Workbench, either a disk version or a download version that works with Q-emuLator? I can send you a photo of my copy including case and mdvs if you like. How much would you charge for that?
I have decided to dabble in 68008 assembler just for a bit of fun. I don't expect to actually produce anything beyond playing around with a bit of arithmetic and branching.
I notice that the files are available on the Quanta Library - I am no longer a member, but is the program public domain now?
Thanks
Jean-Yves
a.k.a. Jean-Yves
Sparrowhawk wrote:Forgive me for jumping in here chaps, but as this is related:
Thanks
Jean-Yves
Hi Jean-Yves,
Yes of course I can do that - on this occasion - no charge...
The copyright situation is difficult to ascertain - Talent believe that Quanta purchased the rights off them to Assembler Workbench and it is available still to Quanta members as part of the Quanta library.
Unfortunately, I have not been able to get clarification from Quanta as to whether they own the rights or are willing to make it public domain, as the version in the library has had several changes made to it by Quanta members....
Sparrowhawk
Thanks for the quick reply Rich..
Seems like you must spend much of your life trying to ascertain the copyright status of QL software! :)
a.k.a. Jean-Yves
