Delete in sQLux
Delete in sQLux
Hi there,
I noticed an issue, maybe it's just me, but if I try to delete a file that doesn't exist in sQLux (I'm using the emulator on the forum), then it just hangs up.
Delete with nothing behind it gets you "bad parameter".
Delete with anything other than a valid file name gives the hang behaviour, even with QLiberator error trapping. The upshot of this is that all the text adventures that I have written hang up when you go to save your position, which I imagine would be infuriating. I'm sure my name must have been cursed a few times by now, as I've only just discovered this!
I can cure this by using TK2's SBYTES_O rather than DELETE (with error trapping) followed by SBYTES, but it will take a wee while to fix all the ones I still have source code for, then recompile and zip and upload them.
Any thoughts? Anyone else seen this?
Alan
Alan
Finding Evan - a text adventure with graphics for SMSQ/E & QDOS
Otis Travels In Space - QDOS only... Find them here!
Re: Delete in sQLux
the online sQLux is still v1.0.6
the release is v1.1.1
have you tried the release version ?
Hope it helps
Markus
Hope it helps
Markus
- XorA
- Site Admin
Re: Delete in sQLux
The online emulator does not have a real fs behind it. Ita more of a tech preview than anything
Re: Delete in sQLux
No I haven't, Markus, it all looks a bit complicated. I prefer an oven-ready downloaddesin wrote: Sun Jun 01, 2025 10:25 am the online sQLux is still v1.0.6
Hope it helps
Markus
It's pretty amazing even so. I am currently trying to get family members to beta test stuff for me, and this is a great way of doing it for people who have never used a QL before. Just give them the web address and email them a .win file. No need to install emulators.XorA wrote: Sun Jun 01, 2025 10:29 am The online emulator does not have a real fs behind it. Ita more of a tech preview than anything
Alan
Re: Delete in sQLux
Thanks to Markus, I have now tried v1.1.1 and there are no problems with the delete operation.desin wrote: Sun Jun 01, 2025 10:25 am the online sQLux is still v1.0.6
Hope it helps
Markus
Alan
Re: Delete in sQLux
Is it really possible to use a *.win file with the forum online emulator?
If yes, how todo that?
Is it then possible to use the Pointer Environment?
- XorA
- Site Admin
Re: Delete in sQLux
Press the Browse button, select .win file, be a winner! (or in theory, its been ages since I tested it)
- XorA
- Site Admin
Re: Delete in sQLux
Seems to work, and PtrEnv works, but its a bit slow on moving the mouse pointer!
Re: Delete in sQLux
I'm shocked! This is working like a charm :‑D
I've uploaded my normal WIN-file (Minerva-version!) and LRUNed the boot file. IT WORKED!
It looks differently than on my PC, but that's because of the resolution (on my PC I'm using 1024x768).
p.s.: Wow! Even MicroEMACS is running (NOT in the screenshot)! But I cannot resize it (most probably, because MicroEMACS cannot be made smaller than 512x256).
