mdump & SGC
mdump & SGC
Has anyone managed to use Daniele's mdump with an SGC please?
After choosing MDV1 or MDV2 I immediately get "bad or changed medium"
The reason I ask is that my main QL has the best of my microdrives for mdump but every time I unplug/re-plug the SGC I risk bending a pin (for some reason) and every time I open the QL to fix that I tend to break a Schon ribbon lead cable
Today I not only bent a pin but broke 3 Schon cables fixing the bent pin
For now I've replaced the Schon with a normal QL keyboard until I can make a complete set of new cables, so I guess other than the bent pin I've less reason to worry now (will open the QL each time I re-fit it)
I've tried slowgold but it has no effect on the problem
