Flush keyboard buffer
How can I flush the keyoard buffer?
The Superbasic Manual says:
When KEYROW is used, any characters in the type-ahead buffer are cleared, therefore, if you wish to avoid accidental input by the user of unwanted keys, you could use:
dummy = KEYROW(0): Quit$ = INKEY$(-1)
But this is not working for me in QPC or sQLux
Re: Flush keyboard buffer
Could the FLUSH #channel keyword (TK2) be used. Can't remember if it is procedure or function. Possibly can only be used on file channels, not sure.
dilwyn wrote: Wed Jul 24, 2024 3:23 pm Could the FLUSH #channel keyword (TK2) be used. Can't remember if it is procedure or function. Possibly can only be used on file channels, not sure.
It can be used only on file channels.
Andrew wrote: Wed Jul 24, 2024 4:02 pm
What's wrong with
REPEAT key : IF INKEY$="" : EXIT key
tofro wrote: Wed Jul 24, 2024 6:00 pm
That's what I did in the end! :D
