Original JS ROM Set
Original JS ROM Set
I was wondering if anyone has an original JS ROM set they'd be willing to sell please?
(For my use on this QL I don't think I'll have the head room for one of Chr$ ROM Boards)
Tony
Tony
Re: Original JS ROM Set
Hi Tony
I should have some JS ROMS, I will check and get back to you.
Many thanks DerekDerek_Stewart wrote: Thu Jul 11, 2024 5:01 pm Hi Tony
I know, from a previous thread, that I can't use 2 x 32KB EPROM in the QL (without modifications to the mobo)
But reading a few threads on here there seems to be some suggestion that 1 x 64KB EPROM could be used (without modifications?)
Is this just a wishful interpretation or actually correct please?
Just looking for a temporary solution until I have some real JS ROM's
Thinking about it I guess even if that did work it would tie up the 16k at $c000 knocking out things like QIMSIt0nyt wrote: Sat Jul 13, 2024 10:30 am I know, from a previous thread, that I can't use 2 x 32KB EPROM in the QL (without modifications to the mobo)
- Aurora
If a MK1 Minerva would fit in your QL. You could burn the JS code onto a 64K EPROM and replace the Minerva ROM wit it.
Hi MartinMartin_Head wrote: Sat Jul 13, 2024 11:13 am If a MK1 Minerva would fit in your QL. You could burn the JS code onto a 64K EPROM and replace the Minerva ROM wit it.
I took the plunge with one of Chr$ daughter boards I had spare this morning and it turns out it will JUST fit in this QL (but it's Minerva 1.98 A1, and I'd prefer JS ROM) so have PM'd Chr$ to see if he can supply me a JS one to save troubling Derek
Would the 64K EPROM not prevent QIMSI and other ROM Port plug-ins working at $C000 though?
Just to be clear, my concern about Chr$ board fitting was related to the QL, not the boards
They are excellent and I use them in all my other QL’s!
- Aurora
The MK1 Minerva had a logic IC under the EPROM that switched the EPROM out at $C000 to leave the ROM port free. If you look at a Minerva ROM it should be a 64K one. I don't know about the EPROM that Chr$ uses.t0nyt wrote: Sat Jul 13, 2024 11:21 amHi MartinMartin_Head wrote: Sat Jul 13, 2024 11:13 am If a MK1 Minerva would fit in your QL. You could burn the JS code onto a 64K EPROM and replace the Minerva ROM wit it.
It will if the TK2 part of the 64k EPROM is enabled with the jumper.... with it disabled the 16k starting at $C000 is free to be used by whatever is using the normal ROM port 16k chunk.t0nyt wrote: Sat Jul 13, 2024 11:21 am
