Noisy MDV
Noisy MDV
The working MDV2 I fitted in my main QL is quite noisy (compared to the whisper quiet MDV1)
This is without any cartridge inserted and just typing dir mdv2_
With the lid off the noise is definitely the motor and I’ve tried adjusting the roller to no avail
Given it’s working (read/write/format) is it worth changing the motor with one from a donor MDV? Or is it best left alone given it’s fully working and the least used?
Any thoughts please?
Re: Noisy MDV
Springs?Chris_68 wrote: Tue Feb 06, 2024 7:57 pm Hi,
Have you verified that the springs are applying enough pressure?
Re: Noisy MDV
The only springs I was aware of are on the right of each mdv with the switch, but these don’t come into play if there’s no cartridge inserted?
- Derek_Stewart
Re: Noisy MDV
I had a noisy microdrive and resolved it using some 'slug slime' - a fine modelers lubricant - just a drop on the top and bottom of the motor, and run it for a while - it should quieten down.
- Derek_Stewart
Re: Noisy MDV
Was the problem a noisy motor? and the lubricant lubricated the motor drive shaft?Pr0f wrote: Wed Feb 07, 2024 7:18 am I had a noisy microdrive and resolved it using some 'slug slime' - a fine modelers lubricant - just a drop on the top and bottom of the motor, and run it for a while - it should quieten down.
Re: Noisy MDV
Hi Derek, will PM you thanksDerek_Stewart wrote: Tue Feb 06, 2024 11:41 pm Hi,
I have spare microdrive units available if required.
