PSU for VRetro PSU?
PSU for VRetro PSU?
I’ve ordered one of Charlie’s QL power supplies and I was wondering if anyone could recommend a suitable power supply I could order from Amazon uk please?
They seem to have a variety of power supplies and I can’t decide what might be best please
Many thanks for any advise
Re: PSU for VRetro PSU?
I use an old power supply that was destined to be binware - there are quite a few on ebay that will work fine. The main thing is to meet the minimum voltage and current capability. Mine was a 12V 2.5A supply - I think originally it was for an external disk drive.
Pr0f wrote: Wed Dec 27, 2023 8:58 am I use an old power supply that was destined to be binware - there are quite a few on ebay that will work fine. The main thing is to meet the minimum voltage and current capability. Mine was a 12V 2.5A supply - I think originally it was for an external disk drive.
All my binware PSU’s went in the bin a long time ago
I don’t really trust old supplies, but a lot of modern ones online look dodgy quality too
Will take a look on eBay as an alternative to Amazon though, thanks
The term binware for me is items in perfectly serviceable order, but for instance in this case - the external disk was failed, the item thrown already - leaving a perfectly good power supply looking for a new home.
Due to a lack of space/storage (I’m a live in carer) I’ve binned just about everything I had from furniture to psu’s. Will have to start again from scratch when I get my own place again in the future
Does a 12v 2a 24w walwart seem ok please?
Chris_68
Post by Chris_68 »
Hi
The voltage regulator inside the Ql is a 1.5 or 2A so you should be fine, if you can get a 2.5A that is better .
Don't forget to buy one with the correct diameter for the barrel connector.
Chris_68 wrote: Wed Dec 27, 2023 10:52 am Hi
Thanks. Can’t see much in the way of 2.5a but there’s 3a - would that be ok please?
should be more than adequate :-) That gives plenty of extra for any plug in cards too.
Pr0f wrote: Wed Dec 27, 2023 11:38 am should be more than adequate :-) That gives plenty of extra for any plug in cards too.
1024MAK
Post by 1024MAK »
The maximum current rating can be higher (within reason) but not lower.
If buying on a trading site, use a seller from your own country that has a good reputation or buy a known brand that has a good reputation.
Stay clear of low quality imports from the far east, as often these completely ignore good engineering practice, and hence may not be particularly safe.
Both for you and for the equipment.
Mark
:!: Standby alert :!:
“There are four lights!”
