Sprites
Sprites
Can QPTR SPRITES, be used in games?
Re: Sprites
You can, of course, do something like that (Provided that you have QPTR loaded):
100 REMark Test whether QPTRsprites are any good for animation....
110 spr32=ALCHP(SPRSP(20,10))
120 REMark define a sprite for mode we're in
130 SPHDR spr32;20,10,0,0;RMODE
140 linum% = 0
150 SPLIN spr32,linum%,'    uu    '
160 SPLIN spr32,linum%,' u  yy  u '
170 SPLIN spr32,linum%,' w  yy  w '
180 SPLIN spr32,linum%,' wuuwwuuw '
190 SPLIN spr32,linum%,'   yyyy   '
200 SPLIN spr32,linum%,'  ayyyya  '
210 SPLIN spr32,linum%,' aayyyyaa '
220 SPLIN spr32,linum%,'a aayyaa a'
230 SPLIN spr32,linum%,'a ayyyya a'
240 SPLIN spr32,linum%,'aaauuuuaaa'
250 :
260 REMark Now the keyboard loop
270 x% = 100 : y% = 100
280 REMark set up a background buffer
300 buffer = PSAVE (0; 0, 0; 20, 10, 100, 100; 20, 10)
310 REPeat k_loop
320    k = KEYROW(1)
340    xold% = x% : yold% = y%
350    SELect ON k
360      =8: EXIT k_loop :REMark ESC pressed
370      =1: REMark ENTER
380      =2: x% = x% - 2: REMark LEFT
390          IF x% < 0 : x% = 0
400      =16: x% = x% + 2 : REMark right
410          IF x% > 512 : x% = 512
420      =128: y% = y% + 2 : REMark down
430           IF y% > 256 : y% = 256
440      =4: y% = y% - 2: REMark up
450           IF y% < 0 : y% = 0
460    END SELect
470    REMark restore screen under sprite, keep buffer
480    PREST buffer, 0, 0; 20, 10; xold%, yold%; 1
490    REMark Now save area under new sprite
500    dummy = PSAVE(buffer; 0, 0; 20, 10; x%, y%)
510    REMark and display the sprite
520    WSPRT x%, y%, spr32
530    REMark wait a tick to slow down the computer
540    SUSJB -1,1
550 END REPeat k_loop
As always with S*BASIC, you might want to adjust the delay in line 540 to accommodate your QPC, and the limits in line 410 and 430 need to be adapted to your window size. It's relatively unlikely that anything but a fast emulator is quick enough for smooth animation from S*BASIC, however.
BTW: With newer Turbo compilers, this does compile and run fine, even if the QPTR manual says otherwise.
Re: Sprites
Hi Tofro,
Excellent, just confirms what I thought, ever since I bought the QPTR Toolkit when it first appeared, I did wonder if this could done. Which relied on the purchsse of QPTR Toolkit, but now QPTR is free, this might a good solution.
