re-discovering the QL... mandelbrot 1989-2023
mrzap000
Post by mrzap000 »
Hi folks,
silently been on this forum for some 8 years, switched on my QL last time in 2015. Been coding since the '80s as a pastime, mostly C/C++/python on linux, all sort of useless stuff from 3d libraries for 3d games in console mode, to new languages (both interpreted and compiled). Re-discovered QPC2 recently and started porting programs I recovered from my QL floppies and... modernising them a bit.
My Mandelbrot generator from 1989 was running in mode 8 (screenshot from QPC2). Worked on it a bit and ported to QPC2 with high-colour, supersampling (up to 8x8), rectangle checking (considerable speedup on homogeneous areas), bookmarks, auto iterations, choice of colouring algorythms, advancement bar with ETA, etc.
Compiled with Turbo, not much of a change not sure whether SBASIC SMSQ/E on QPC2 is very fast or there are better compilers than Turbo... can't force myself to write the inner Mandelbrot loop in asm... so it's still obviously slow, beign a SBASIC program, despite heavy optimization (including now a good +10% speed by switching to GOSUB vs FuNction as a function call seems to be taking more time, likely in allocating stack for LOCal variables and dealing with parameters and the RETurn value). Yet oddly satisfying to me... watching those beatiful shapes being painted in front of me. Not much of a point making it some % faster, when any iPAD with Apple M1 can animate Mandelbrot in real time.
It's still in Italian, not sure it would be of interest to anybody... meanwhile here's a screenshot from V5.00, coming 34 years after V1.01. [edit]: it still works in MODE 4 at 512x256, with 22 colors simulated with stipples. The image below is calculated with 3x3 supersampling, that makes the picture more "readable" (less noise near the boundary of the Mandelbrot set).
Screenshot 2023-03-18 134812.png (6.1 KiB) Viewed 5023 times
Re: re-discovering the QL... mandelbrot 1989-2023
Hi
The Mandelbrot sets look great.
I remember seeing Gerge Gwilt do this type of thing in assembler, really slick.
I can not SBASIC being faster thsn Turbo compiled. But it might fun to see the difference.
Derek_Stewart wrote: Sat Mar 18, 2023 3:59 pm Hi
SBASIC is really blazingly fast compared to SuperBASIC - Turbo will only be able to generate a very moderate speed increase. So what you see is not Turbo being inept, but rather SBASIC close to perfect...
Apart from my spelling and grammar errors, I was hoping for a comparison of SuperBASIC and SBASIC to Turbo compiled when performing Mandelbrot Set generation.
Not SuperBASIC against SBASIC, it is well known that SBASIC is faster, can execute basic programmes. Whereas QDOS requires Minerva v1.90 owards to Multibasic.
mrzap000
Post by mrzap000 »
Derek_Stewart wrote: Sun Mar 19, 2023 8:39 am Hi,
quick comparison: basic set, 960 x 510 points, 512 iterations, no rectangle checking (all points calculated individually), SBASIC = 88s, Turbo compiled code = 40s
same as above with 1024 iterations, 480 x 255 points, SBASIC = 40s, Turbo = 18s
So it would seem Turbo is about 55% faster than SBASIC on my particular code. The SBASIC core iteration uses well-known formulas to minimise the cost of FP operations. I think that the difference between SBASIC and Turbo on those few Fp operations would be minimal, as the FP operations time would be predominant over interpreter time, while the one that seems to take much longer in SBASIC is the IF evaluation to exit the loop if iterations reach the max iteration limit. e.g. if one adds the convergence detection (whether the iteration has converged to a point, which means you're in the set anyway and don't need to wait until max iterations), the cost of the extra IF to exit the loop takes more time SBASIC than the time saved on iterations in the set, unless most of the points in the picture are in the set.
Also, I found that there's a 10% cost in Functions vs GOSUB, likely due to stack operations on FuNction entry/exit and LOCal variable allocation.
BTW anyone remembers where QDOS FP operations in assembler are documented? was it the Technical guide? not sure I'll do it but it would be nice to try and code the mandel loop in assembler
Cristian
Post by Cristian »
Ciao Roberto,
and welcome back ti the QL scene!
Your Mandelbrot program looks very interesting, I'm looking forward to try it with my QLs
mrzap000
Post by mrzap000 »
Hi there. While moving with family to a new flat, not much time these days... thought I would put the program on a public Bitbucket repo, you can download it from there https://bitbucket.org/mrzap000/mandel/src/master/
mrzap000
Post by mrzap000 »
Decided to rediscover the 68k assembly language and try to implement a mandelbrot code iteration in asm with fixed point integers. 1st go used 16bit due to the 68k 16-bit MULS/MULU limitation (16bit operands). Limited to 11 bits after decimal point. 2nd go implemented a 64bit multiplication with 32bit operands. Works up to 26 bits after decimal point. Limited magnification and the 64bit product is significantly slower on QPC2. With 16/32bit integer math it is fast enough, even in SBASIC, to animate in low resolution in real time. The SBASIC program calls the Mandelbrot iteration via CALL address,Cre,Cim where Cre=(C real)<<precision etc.
will post link to video of animation when I have some time
sample asm code from the 16/32 bit version, unoptimized and ugly, followed by sample program (with test procedures)
vcim	equ	4
vcre	equ	8
vrad	equ	12
vrad2	equ	16
vfac	equ	20
	section code
	bra	start
	nop
maxiter dc.w	200
	dc.w	0
	dc.l	0
	dc.l	0
	dc.l	4
	dc.l	0
	dc.w	11
	nop
start
	lea	maxiter,a1
	moveq	#0,d0	m%
	clr.l	d3	zresq
	clr.l	d4	zimsq
	clr.l	d5	zre
	clr.l	d6	zim
	move.l	d1,vcre(a1)
	move.l	d2,vcim(a1)
	clr.l	d1
	move.w	vfac(a1),d1
	clr.l	d2
	move.l	vrad(a1),d2
	lsl.l	d1,d2
	move.l	d2,vrad2(a1)
loop1
	move.l	d5,d7
	lsl.l	#1,d7	zre*2
	muls	d6,d7	zim*zre*2
	lsr.l	d1,d7
	add.l	vcim(a1),d7   cim+zim*zre*2
	move.l	d7,d6	=zim
	move.l	vcre(a1),d7   cre
	add.l	d3,d7	zresq+cre
	sub.l	d4,d7	zresq+cre-zimsq
	move.l	d7,d5	=zre
*	 move.w  d5,d7	 zre
	muls	d5,d7	zre*zre
	lsr.l	d1,d7
	move.l	d7,d3	=zresq
	move.l	d6,d7	zim
	muls	d6,d7	zim*zim
	lsr.l	d1,d7
	move.l	d7,d4	=zimsq
	addq.w	#1,d0
	cmp.w	(a1),d0
	ble	jump1
	clr.l	d0
	bra	exit
jump1
	move.l	d3,d7
	add.l	d4,d7
	cmp.l	vrad2(a1),d7
	ble	loop1
exit
	move.w	d0,2(a1)
	clr.l	d0
	rts
	end
using CST Quanta ASM
SBASIC program
100 DEFine PROCedure init(f$)
105 IF f$="":fb$="win2_test":ELSE fb$=f$
110 EXEP qd;fb$&"_asm"
120 a=ALCHP(1000)
130 fact=11:f=2^fact
140 END DEFine
150 DEFine PROCedure setfact(f1)
160 fact=f1:f=2^f1
170 END DEFine
180 DEFine PROCedure asm
190 EXEP dev2_qmac;fb$
200 PAUSE
210 EXEP dev2_qlink;fb$
220 END DEFine
230 DEFine PROCedure ld(a)
240 LBYTES win2_test_bin,a
250 END DEFine
260 DEFine PROCedure dump(a)
270 LOCal i
280 FOR i=a TO a+136 STEP 2:PRINT HEX$(PEEK_W(i),16)!!
290 PRINT
300 END DEFine
310 DEFine FuNction mandel(cim,cre)
320 CALL a,INT(cre*f),INT(cim*f)
330 RETurn PEEK_W(a+8)
340 END DEFine
350 DEFine PROCedure drawmandel(iter%,bs%,pixels,x,y,dx,dy)
360 LOCal x%,y%,m,i,j,i2%,stx,sty,infx,infy,supx,supy,xs%,ys%
362 IF dx=0 OR dy=0:infx=-2:supx=1:infy=-1.5:supy=1.5:ELSE infx=x:infy=y:supx=x+dx:supy=y+dy
363 IF bs%=0:bs%=2
364 IF pixels=0:pixels=150
365 xs%=bs%:ys%=bs%
370 stx=(supx-infx)/pixels*xs%:sty=(supy-infy)/pixels*ys%
380 POKE_W a+6,iter%
390 REMark POKE_W a+26,fact
400 x%=0
410 FOR i=infx TO supx STEP stx
420 y%=0
430 i2=INT(i*f)
440 FOR j=infy TO supy STEP sty
450 CALL a,i2,INT(j*f)
460 m=(PEEK_W(a+8)*3)MOD 256
470 BLOCK xs%,ys%,x%,y%,m*3+m*512+m*65536:y%=y%+ys%
480 END FOR j
490 x%=x%+xs%
500 END FOR i
510 END DEFine
520 :
522 fb$="win2_test"
525 COLOUR_24
530 a=ALCHP(200)
540 ld a
550 setfact 10
560 drawmandel 200
570 RECHP a
580 PAUSE
790 DEFine PROCedure animate
795 LOCal i,d
800 FOR i=1 TO 7 STEP 7E-2:d=10/2^i:drawmandel 100,3,200,-1.03+(.4-d)/2,-.4+(.4-d)/2,d,d
810 END DEFine
If you need/want a 32 bit by 32 bit multiply routine, then Issue 11 of the extremely random eMagazine on Assembly Programming has on which I wrote and is free for all to use. You can get the PDF and code files at https://github.com/NormanDunbar/QLAssem ... g/Issue_11 if you wish.
Your mandlebrot set image looks excellent.
mrzap000
Post by mrzap000 »
NormanDunbar wrote: Fri Mar 31, 2023 7:43 pm If you need/want a 32 bit by 32 bit multiply routine, then Issue 11 of the extremely random eMagazine on Assembly Programming has on which I wrote and is free for all to use. You can get the PDF and code files at https://github.com/NormanDunbar/QLAssem ... g/Issue_11 if you wish.
can't thank you enough, I used to love programming in 68k assembler back in the 80's but I'm soo rusty now... great reading, will go through your eMagazine for sure!!
btw, I gave it a go myself, based on some theory I found on the web, but the resulting set gets fuzzy on high magnification instead of blockly, which is what you'd expect when reaching the limits of the 26-bit precision.. I guess I'm doing something wrong, I'll look into yours, thank you!
* subroutine to multiply two 32 bit integers
* d1,d2 operands
* result in d2
* vfac(a1) holds the precision in bits (i.e. 26)
* the comments assume AB CD are two 32bit integers holding fixed-point numbers with vfac(a1) bits of precision
* the most significant longword is discarded, we only keep the least significant longword as a result for our mandelbrot set as all other calculations are on 32 bits
mul32
	move.w	d1,d3	b
	move.w	d2,d4	d
	mulu	d3,d4	b*d
	move.l	d4,d5	b*d
	move.w	d1,d3	b
	swap	d2
	move.w	d2,d4	c
	mulu	d3,d4	b*c
	move.l	d4,d6	b*c
	swap	d1
	move.w	d1,d3	a
	swap	d2
	move.w	d2,d4	d
	mulu	d3,d4	a*d
	add.l	d4,d6	b*c+a*d
*	 moveq	 #16,d3
	swap d6
*	 lsl.l	 d3,d6	 (b*c+a*d)<<16
	move.w	d5,d6	(b*c+a*d)<<16 + b*d
	move.w	d1,d3	a
	swap	d2
	move.w	d2,d4	c
	muls	d3,d4	a*c
* now lower 32bit in d6, higher 32 bit in d4, must shift right
	move.l	vfac(a1),d3
	move.l	d4,d5	high 32 in d5
	ror.l	d3,d5	rotate right by factor
	move.l	d4,d2	high longword in d2
	lsr.l	d3,d2	shift right by factor - d2 is now the light 32
	eor.l	d2,d5	now in d5 just the left bits that must go to  the lower 32
	lsr.l	d3,d6
	or.l	d5,d6	now in d6 the full low 32 shifted by d3
	move.l	d6,d2	we just take the lower 32 as a return value
	rts
